jgb Posted June 26, 2018 Posted June 26, 2018 Hi, I installed an Epson TM-T20 II without problem using the armbian image for z28 tvbox, rockchip rock64 alike board. When I plug it, it creates a /dev/usb/lp0 port that is enough to make the printer work. But I am unable to get the same working on the amlogic images. No port is created when I add the USB printer. Could it be missing UDEV rules? Or usblp driver not being loaded by the kernel? May someone give me a light? Those boxes are optimal for POS installations, and no support for ticket printing is a handicap. BTW, awesome work with all this project, it helped me a lot.
Igor Posted June 26, 2018 Posted June 26, 2018 On 6/26/2018 at 3:38 PM, jgb said: But I am unable to get the same working on the amlogic images. Expand Without investigating. Kernels are usually from different eras and their configurations are also not unified. It's some work to get to such plug and play state. That would easily explain why you have problems.
martinayotte Posted June 26, 2018 Posted June 26, 2018 Could be so many things, such missing VUSB in DT, missing driver in defconfig ... First thing to check is what "lsusb" reporting on both boards.
