14 minutes ago, Dospayne2 said:
help with the connection
orange pi pc
There are too little informations to tell you anything. You always provide system logs, otherwise, most likely, nobody will even try to help you:
armbianmonitor -u
armbianmonitor -u
Network/firewall problem detected. Not able to upload debug info.
Please fix this or use "-U" instead and upload whole output manually
System diagnosis information will now be uploaded to curl: (6) Could not resolve host: sprunge.us
gzip: /var/log/armhwinfo.log.1.gz: No such file or directory
Please post the URL in the forum where you've been asked for.
Aha, we need to push an update ... to fix this problem. It's still present on old builds.  Paste
dmesg
somewhere with an attached adaptor.
dmesg
Could not find the database of available applications, run update-command-not-fo        und as root to fix this
dmesg: command not found
What about doing exactly this? 'armbianmonitor -U' (capital U) and then posting/pasting this stuff to e.g. https://pastebin.com?
4 minutes ago, Igor said:
Well, two things are essential:
lsusb
to see ID of the chip
kernel version
It's possible that this wifi is not supported, which is obvious since you are asking here, and do it this way: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 0e8f:00fb GreenAsia Inc.
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 004: ID 2001:3319 D-Link Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
You can proceed with my link and build the driver since its apparently 8192EU, which is covered by our example. In case you don't get proper headers, you will need to switch to a nightly repository. In case our recipe doesn't work, proceed this way: https://www.google.si/search?q=2001%3A3319
Remember just that headers package name at armbian is not the same as on x86/generic install. So use our armbian-config method of isntalling.
That's all help you can get here. Other problems are related to the driver sources ... which is out of our power anyway.
