Igor Posted July 9, 2018 Posted July 9, 2018 14 minutes ago, Dospayne2 said: help with the connection orange pi pc There are too little informations to tell you anything. You always provide system logs, otherwise, most likely, nobody will even try to help you: armbianmonitor -u
Dospayne2 Posted July 9, 2018 Author Posted July 9, 2018 1 minute ago, Igor said: There are too little informations to tell you anything. You always provide system logs, otherwise, most likely, nobody will even try to help you: armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually System diagnosis information will now be uploaded to curl: (6) Could not resolve host: sprunge.us gzip: /var/log/armhwinfo.log.1.gz: No such file or directory Please post the URL in the forum where you've been asked for.
Igor Posted July 9, 2018 Posted July 9, 2018 Aha, we need to push an update ... to fix this problem. It's still present on old builds. Paste dmesg somewhere with an attached adaptor.
Dospayne2 Posted July 9, 2018 Author Posted July 9, 2018 1 minute ago, Igor said: Aha, we need to push an update ... to fix this problem. It's still present on old builds. Paste dmesg  somewhere with an attached adaptor. Could not find the database of available applications, run update-command-not-fo und as root to fix this dmesg: command not found
tkaiser Posted July 9, 2018 Posted July 9, 2018 4 minutes ago, Dospayne2 said: Please fix this or use "-U" instead and upload whole output manually What about doing exactly this? 'armbianmonitor -U' (capital U) and then posting/pasting this stuff to e.g. https://pastebin.com?
Dospayne2 Posted July 9, 2018 Author Posted July 9, 2018 10 minutes ago, tkaiser said: What about doing exactly this? 'armbianmonitor -U' (capital U) and then posting/pasting this stuff to e.g. https://pastebin.com? putty truncates the text
Igor Posted July 9, 2018 Posted July 9, 2018 Well, two things are essential: lsusb to see ID of the chip kernel version It's possible that this wifi is not supported, which is obvious since you are asking here, and do it this way: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver
Dospayne2 Posted July 9, 2018 Author Posted July 9, 2018 27 minutes ago, tkaiser said: What about doing exactly this? 'armbianmonitor -U' (capital U) and then posting/pasting this stuff to e.g. https://pastebin.com? https://pastebin.com/3NAW4igX
Dospayne2 Posted July 9, 2018 Author Posted July 9, 2018 4 minutes ago, Igor said: Well, two things are essential: lsusb to see ID of the chip kernel version It's possible that this wifi is not supported, which is obvious since you are asking here, and do it this way: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 002: ID 0e8f:00fb GreenAsia Inc. Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 004: ID 2001:3319 D-Link Corp. Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Igor Posted July 9, 2018 Posted July 9, 2018 You can proceed with my link and build the driver since its apparently 8192EU, which is covered by our example. In case you don't get proper headers, you will need to switch to a nightly repository. In case our recipe doesn't work, proceed this way: https://www.google.si/search?q=2001%3A3319 Remember just that headers package name at armbian is not the same as on x86/generic install. So use our armbian-config method of isntalling. That's all help you can get here. Other problems are related to the driver sources ... which is out of our power anyway.
tkaiser Posted July 9, 2018 Posted July 9, 2018 8 minutes ago, Dospayne2 said: https://pastebin.com/3NAW4igX 'Linux 3.4.113-sun8i (RetrOrangePi)' -- no idea what RetrOrangePi folks do to Armbian images
