Gaaarfild Posted July 9, 2018 Posted July 9, 2018 (edited) Hello everyone. Tried to use GPIO. Installed the necessary C library. # ls -l /sys/class/gpio/ total 0 --w------- 1 root root 4096 Jul 9 23:40 export lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1000 -> ../../devices/platform/pinctrl/gpio/gpiochip1000 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1024 -> ../../devices/platform/pinctrl/gpio/gpiochip1024 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1056 -> ../../devices/platform/pinctrl/gpio/gpiochip1056 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1088 -> ../../devices/platform/pinctrl/gpio/gpiochip1088 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1120 -> ../../devices/platform/pinctrl/gpio/gpiochip1120 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1152 -> ../../devices/platform/pinctrl/gpio/gpiochip1152 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1184 -> ../../devices/platform/pinctrl/gpio/gpiochip1184 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1216 -> ../../devices/platform/pinctrl/gpio/gpiochip1216 lrwxrwxrwx 1 root root 0 Jul 9 23:43 gpiochip1248 -> ../../devices/platform/pinctrl/gpio/gpiochip1248 --w------- 1 root root 4096 Jul 9 23:43 unexport As you can see, there are some weird numbers. The only one pin I could find was gpiochip1184. It was pin 184. Others not even match a pattern of last 3 numbers. Maybe you could help me, what is wrong there? Model: Asus Tinker Board S. Thank you. Edited July 9, 2018 by Gaaarfild
TonyMac32 Posted July 10, 2018 Posted July 10, 2018 Please provide the output of armbianmonitor -u I had the gpio returned to base 0 (Rockchip decided it should be base 1000 at some point for unclear reasons involving Android if I remember correctly.) If that is not still the case, it could be due to the recent issue with kernels resulting in us reverting to an older kernel source. Some of the the patches that were no longer needed may again need added.
Gaaarfild Posted July 12, 2018 Author Posted July 12, 2018 @TonyMac32 Here are the results of the command: http://ix.io/1h0m
TonyMac32 Posted July 12, 2018 Posted July 12, 2018 Yes, that one is still counting from 1000. Do you need multimedia or touch screen/camera? If not I recommend a mainline kernel, the legacy kernel has sadly taken a turn for the worse recently and needs some work.Sent from my Pixel using Tapatalk
Gaaarfild Posted July 13, 2018 Author Posted July 13, 2018 Thank you! Currently, I don't need any cameras or screens at all. How do I forcefully update a kernel? To install the specific version manually?
Igor Posted July 13, 2018 Posted July 13, 2018 16 minutes ago, Gaaarfild said: To install the specific version manually? armbian-config -> system -> alternative kernels -> next
Gaaarfild Posted July 13, 2018 Author Posted July 13, 2018 @Igor Thank you very much. It was quite easy Now GPIO looks a bit different. But I still don't see most of the numbers in GPIO table $ ls /sys/class/gpio/ export gpiochip0 gpiochip120 gpiochip152 gpiochip184 gpiochip216 gpiochip24 gpiochip248 gpiochip56 gpiochip88 unexport This is a table: $ sudo gpio readall +-----+-----+---------+------+---+--Tinker--+---+------+---------+-----+-----+ | CPU | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | CPU | +-----+-----+---------+------+---+----++----+---+------+---------+-----+-----+ | | | 3.3v | | | 1 || 2 | | | 5v | | | | 252 | 8 | SDA.1 | I2C | 1 | 3 || 4 | | | 5v | | | | 253 | 9 | SCL.1 | I2C | 1 | 5 || 6 | | | 0v | | | | 17 | 7 | GPIO0C1 | IN | 0 | 7 || 8 | 1 | SERL | TxD.1 | 15 | 161 | | | | 0v | | | 9 || 10 | 1 | SERL | RxD.1 | 16 | 160 | | 164 | 0 | CTSN.4 | SERL | 1 | 11 || 12 | 1 | I2S | I2S_CLK | 1 | 184 | | 166 | 2 | GPIO5B6 | IN | 0 | 13 || 14 | | | 0v | | | | 167 | 3 | GPIO5B7 | IN | 1 | 15 || 16 | 1 | IN | GPIO5B2 | 4 | 162 | | | | 3.3v | | | 17 || 18 | 1 | IN | GPIO5B3 | 5 | 163 | | 257 | 12 | MOSI.2 | SPI | 0 | 19 || 20 | | | 0v | | | | 256 | 13 | MISO.2 | SPI | 1 | 21 || 22 | 0 | IN | GPIO5C3 | 6 | 171 | | 254 | 14 | SCLK.2 | SPI | 1 | 23 || 24 | 1 | SPI | CE0.2 | 10 | 255 | | | | 0v | | | 25 || 26 | 1 | SPI | CE1.2 | 11 | 251 | | 233 | 30 | SDA.4 | I2C | 1 | 27 || 28 | 1 | I2C | SCL.4 | 31 | 234 | | 165 | 21 | RTSN.4 | SERL | 1 | 29 || 30 | | | 0v | | | | 168 | 22 | GPIO5C0 | IN | 1 | 31 || 32 | 1 | SERL | GPIO7C7 | 26 | 239 | | 238 | 23 | GPIO7C6 | SERL | 1 | 33 || 34 | | | 0v | | | | 185 | 24 | I2S_FS | I2S | 0 | 35 || 36 | 1 | SERL | RxD.3 | 27 | 223 | | 224 | 25 | TxD.3 | SERL | 1 | 37 || 38 | 1 | I2S | I2S_SDI | 28 | 187 | | | | 0v | | | 39 || 40 | 0 | I2S | I2S_SDO | 29 | 188 | +-----+-----+---------+------+---+----++----+---+------+---------+-----+-----+ | CPU | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | CPU | +-----+-----+---------+------+---+--Tinker--+---+------+---------+-----+-----+ Also one more armbianmonitor output: http://ix.io/1d8o
