Just came across this
Might be useful for developers
Improved Optimization/speed and wear leveling of software on SD Cards
https://lwn.net/Articles/428584/
It's an older report...but it might help since devices are getting bigger and the need to keep the cards alive longer is getting more and more important
My take on the document is that 4MB blocks or when writing the image
Write to SD card using Linux:
- Find the device (eg: /dev/sdb1) you need to write to by using blkid or mount.
- Double check that you have the correct dev path for your SD card (eg: /dev/sdb1).
- Unmount the SD card and all its partitions by using umount /dev/sdb?.
- Write the image using dd if=/path/to/DietPi_vXX.img of=/dev/sdb.
sudo dd if=/path/to/DietPi_vXX.img of=/dev/sdb bs=4096
or
sudo dd if=/path/to/DietPi_vXX.img of=/dev/sdb bs=4M
That's irrelevant since it happens above the filesystem layer.
It's all about partition alignment. I changed this last year to 4MB boundaries.
This resulted in a partition alignment at 4 MB boundaries (before we were using 1 MB) so after this change less wear on SD card but '3 MB wasted'.
Since unlike other projects we do not promote the use of old, small and crappy SD cards and the minimum card size you get today is 16GB* I think 'wasting' 3MB on a 16GB card is nothing to care about.
* (personal recommendation: SanDisk Ultra A1 16GB -- but always check prices of the larger variants since at least 32GB are not that much more expensive than the 16GB variant)
The "bs=" means "block size", it has nothing to do with "sector size" of a file system.
It is only the size of the buffer used between reading the source and writing destination.
Of course, a bs=4M will do the transfers faster than a bs=4096, which is not the same since the later means 4096 bytes.
Oh yeah...those A1 cards are STUPID fast...especially when doing apt-get update and upgrades!!!
Thanks for clearing that transfer rate and sector size up...
