hi martinayotte,
I remember you in the past, this is my new account but we have work 4 year on this forum in stratup of armbian. So in clear trust me when I insert the orange pi zero on a specify pcb , the pcb have arm chip on it.
I just start the linux and everything is working well but the second we do apt-get update, the "dpkg configure "  is broken. When I go the dpkg configure -a for fix the issue, who 6 new library forced to be installed
As I said "How a GPIO connection could interact with a Linux filesystem ?" ... Impossible !
Believe me, your issue must be somewhere else : bad PSU or bad SDCard !
3 minutes ago, Jimmy Raymond Belanger said:
orange pi zero - usb 4 pin gpio - exploit buffer overlow inject file by usb gpio voila
Then you talk about an USB issue, not a GPIO issue.. (a pin on a board doesn't mean it's a gpio - general purpose input/output). If you don't want that something on the USB pins on pinheader happens, I think (didn't test) it should be sufficient to just disable the device tree overlay which activate those USBs (as a 'hot fix'), and then probably report it to the sunxi mailing list in case it turns out to be a kernel-issue.
seriouly.... the orange pi zero have 4 GPIO PIN = USB.... usb or gpio same think for me it 4 pin...
my research is private, no information about security is provided.
it just look like the driver send by the controler board have malisious software....
I give you feedback after disable usb gpio port
You should detailed what is that famous board and how it is connected to OPi headers.
If you have it connected only on dual-header, there is no USB there, so no injection possible on those pins ...
And that's where your thinking goes wrong and why @martinayotte immediately thought you must be wrong. Pin != GPIO, otherwise you could argue that the 5V Pin on the pinheader must also be a GPIO. Nevertheless, it might be interesting which 'HAT' you stick to your OPi-Zero (even when it's not a GPIO issue it might be an USB issue, or an issue where this "HAT" doesn't do sane things) and for:
1 hour ago, Jimmy Raymond Belanger said:
sometime the pcb inject file inside the linux and create dpkg error.
it might be interesting to see some logs so that others can have a look whats going on here.. e.g. an 'armbianmonitor -u' could be a good starter?
