Sigge Posted July 11, 2018 Share Posted July 11, 2018 Hi, trying to install or compile v4l2loopback. I fail with missing header message. I have tried armbian-config and apt-get for the headers but all fails. I have tried stable and dev. Anyone know how to do this? orangepiplus2e:/lib/modules/4.17.5-sunxi$ sudo apt-get install v4l2loopback-dkms Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: dkms Suggested packages: python3-apport menu v4l2loopback-utils Recommended packages: fakeroot linux-headers-686-pae | linux-headers-amd64 | linux-headers-generic | linux-headers The following NEW packages will be installed: dkms v4l2loopback-dkms 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/107 kB of archives. After this operation, 397 kB of additional disk space will be used. Do you want to continue? [Y/n] Y Selecting previously unselected package dkms. (Reading database ... 51147 files and directories currently installed.) Preparing to unpack .../archives/dkms_2.3-2_all.deb ... Unpacking dkms (2.3-2) ... Selecting previously unselected package v4l2loopback-dkms. Preparing to unpack .../v4l2loopback-dkms_0.10.0-1_all.deb ... Unpacking v4l2loopback-dkms (0.10.0-1) ... Setting up dkms (2.3-2) ... Processing triggers for man-db (2.7.6.1-2) ... Setting up v4l2loopback-dkms (0.10.0-1) ... Loading new v4l2loopback-0.10.0 DKMS files... Building for 4.17.5-sunxi Module build for kernel 4.17.5-sunxi was skipped since the kernel headers for this kernel does not seem to be installed. Buildning gives me this: orangepiplus2e:~/v4l2loopback$ make Building v4l2-loopback driver... make -C /lib/modules/`uname -r`/build M=/home/aaa/v4l2loopback modules make[1]: *** /lib/modules/4.17.5-sunxi/build: No such file or directory. Stop. Makefile:42: recipe for target 'v4l2loopback.ko' failed make: *** [v4l2loopback.ko] Error 2 Link to comment Share on other sites More sharing options...
Sigge Posted July 11, 2018 Author Share Posted July 11, 2018 This is what I get when trying to install with apt-get: orangepiplus2e:~/v4l2loopback$ sudo apt-get install linux-headers-sun8i Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: linux-headers-sun8i 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 5 811 kB of archives. After this operation, 39,7 MB of additional disk space will be used. Get:1 http://beta.armbian.com stretch/main armhf linux-headers-sun8i armhf 5.52.180710 [5 811 kB] Fetched 5 811 kB in 1s (4 502 kB/s) Selecting previously unselected package linux-headers-sun8i. (Reading database ... 51187 files and directories currently installed.) Preparing to unpack .../linux-headers-sun8i_5.52.180710_armhf.deb ... Unpacking linux-headers-sun8i (5.52.180710) ... Setting up linux-headers-sun8i (5.52.180710) ... Compiling headers - please wait ... orangepiplus2e:~/v4l2loopback$ sudo apt-get install v4l2loopback-dkms Reading package lists... Done Building dependency tree Reading state information... Done Suggested packages: v4l2loopback-utils The following NEW packages will be installed: v4l2loopback-dkms 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/32,6 kB of archives. After this operation, 109 kB of additional disk space will be used. Selecting previously unselected package v4l2loopback-dkms. (Reading database ... 63931 files and directories currently installed.) Preparing to unpack .../v4l2loopback-dkms_0.10.0-1_all.deb ... Unpacking v4l2loopback-dkms (0.10.0-1) ... Setting up v4l2loopback-dkms (0.10.0-1) ... Loading new v4l2loopback-0.10.0 DKMS files... dpkg: warning: version '3.4.113-sun8i 4.17.5' has bad syntax: invalid character in revision number Building for 4.17.5-sunxi Module build for kernel 4.17.5-sunxi was skipped since the kernel headers for this kernel does not seem to be installed. Link to comment Share on other sites More sharing options...
Igor Posted July 12, 2018 Share Posted July 12, 2018 18 hours ago, Sigge said: I fail with missing header message. I have tried armbian-config and apt-get for the headers but all fails. I have tried stable and dev. Switch to automated nightly builds and try default and next kernel, skip DEV. They all have matching headers and repeat the process. Link to comment Share on other sites More sharing options...
Sigge Posted July 12, 2018 Author Share Posted July 12, 2018 Should I do that through armbian-config? Install headers just blink and change kernel only gives me one option that says failed, aborting. Maybe I should reinstall, might have messed up with my attempts. Link to comment Share on other sites More sharing options...
Sigge Posted July 12, 2018 Author Share Posted July 12, 2018 Ok, so I have re flashed my card. Went with: Armbian Stretch mainline kernel 4.14.y Enabled nightly builds and installed headers. So far so good. Updated. orangepiplus2e:~/v4l2loopback$ make VERBOSE=1 Building v4l2-loopback driver... make -C /lib/modules/`uname -r`/build M=/home/aaa/v4l2loopback modules make[1]: Entering directory '/usr/src/linux-headers-4.17.5-sunxi' Building modules, stage 2. MODPOST 1 modules /bin/sh: 1: scripts/mod/modpost: not found scripts/Makefile.modpost:92: recipe for target '__modpost' failed make[2]: *** [__modpost] Error 127 Makefile:1574: recipe for target 'modules' failed make[1]: *** [modules] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-4.17.5-sunxi' Makefile:42: recipe for target 'v4l2loopback.ko' failed make: *** [v4l2loopback.ko] Error 2 So I wanted to try and switch default and next kernel as suggested. However; the only option is to switch from next to dev? This is in "Switch", should I use "Default, install desktop ..." instead? Link to comment Share on other sites More sharing options...
Igor Posted July 13, 2018 Share Posted July 13, 2018 Try: cd /usr/src/linux-headers-4.17.5-sunxi make scripts and repeat building. 1 Link to comment Share on other sites More sharing options...
Sigge Posted July 13, 2018 Author Share Posted July 13, 2018 after: sudo apt-get install bison libbison-dev flex libfl-dev make scripts Sucsess! orangepiplus2e:~/v4l2loopback$ make VERBOSE=1 Building v4l2-loopback driver... make -C /lib/modules/`uname -r`/build M=/home/aaa/v4l2loopback modules make[1]: Entering directory '/usr/src/linux-headers-4.17.5-sunxi' Building modules, stage 2. MODPOST 1 modules CC /home/aaa/v4l2loopback/v4l2loopback.mod.o LD [M] /home/aaa/v4l2loopback/v4l2loopback.ko make[1]: Leaving directory '/usr/src/linux-headers-4.17.5-sunxi' Sucsess! Thank you!! 2 Link to comment Share on other sites More sharing options...
Igor Posted July 13, 2018 Share Posted July 13, 2018 Great! One more thing. Since you switched to beta.armbian.com repository and since this kernel is getting daily updates ... freeze kernel updates. Possible in armbian-config menu ... or manually (apr-mark). Link to comment Share on other sites More sharing options...
Sigge Posted July 13, 2018 Author Share Posted July 13, 2018 Yes, thanks! Did I just mess up or are there no uninstallable headers for the stable version? Link to comment Share on other sites More sharing options...
