Hi, every one:
I installed Armbian Xenial desktop legacy kernel 3.10.y on my OPI win plus , it's good.
(At least, Bluetooth, WIFI and Ethernet are good).
But after i execute "apt upgrade",The bluetooth is fault.
So, I tried to freeze the kernel upgrades, and hold "armbian-firmware"package, then run "apt upgrade", All do not work.
However, when i insert a BT-dongle(USB), this dongle is functional.
So I think there is a bug in some package, please help me to solve.
The problem is most likely in the BSP package, where are all those startup scripts are: linux-root-xenial-orangepiwin
Hi Igor:
Thanks for your reply.
But, I have frozen the kernel upgrade, but there is still a problem.
I remember that freezing the kernel upgrade should mean that the BSP upgrade is also frozen, right?
Where is "linux-root-xenial-orangepiwin"?
If you choose to freeze from armbian-config, this should also be frozen. Then it could be a problem with upstream changes - check which packages, that might be related, are changed.  No other ideas.
Hi, Igor:
Yes, I did freeze them from armbian-config (except armbian-firmware, which was blocked with 'dpkg --set-selections').
It is important to point out that after performing "apt upgrade", After Bluetooth failed, I used the method of freezing upgrade.
However, the freeze upgrade does not seem to solve the Bluetooth failure problem.
The problem I reported can be reproduced steadily. That is:
As long as an upgrade, Bluetooth will definitely fail. (Whether it is freezing the kernel upgrade)
In fact, I have repeatedly flashed the TF card (This means that the installation is fresh) test many times.
I think this problem should be solved...
