I need to compile armbian to set some kernel modules.
Now the compiled kernel is installed and armbian is up.
For some reason using armbin-add-overlay results in
Missing dtc compiler in kernel headers directory. Please reinstall the kernel headers package
I have installed the all packages I have build.
├── linux-dtb-next-sunxi_5.53_armhf.deb
├── linux-headers-next-sunxi_5.53_armhf.deb
├── linux-image-next-sunxi_5.53_armhf.deb
└── linux-u-boot-next-nanopineo_5.53_armhf.deb
So the matching kernel headers should be installed.
4.17.y is still in works. This might be worth reading:
I found the root cause ... bison and flex were missing ...
The kernel header package has a postinst command running make inside the new installed tree.
make -s scripts >/dev/null 2>&1
exit 0
But this does not report anything by design and exits with success. So there was no resulting dtc binary inside
/lib/modules/$(uname -r)/build/scripts/dtc/
