odoll Posted July 28, 2018 Posted July 28, 2018 Maybe a long shot: rather than setting up armbian on my new ESPRESSObin (epb), installing needed SW and tools, porting configs off my Cubietruck (cbt), would it be possible to tweak the cbt's SDcard / FS to boot on the ESPRESSObin? If I'm not mistaken the cbtis armhf based and all those binaries should also run on the epb!? Would it be "good enough" to add the arm64 architecture to the CBT with "dpkg --add-architecture arm64" and then to install linux-u-boot-espressobin-next linux-image-next-mvebu64 linux-headers-next-mvebu64 linux-firmware-image-next-mvebu64 linux-dtb-next-mvebu64 linux-$(lsb_release -cs)-root-next-espressobin shut down the cbt and put the card into the epb, booting it in the epb?
Igor Posted July 28, 2018 Posted July 28, 2018 In theory, if you manage to install those packages ... it should work this way, yes. But it's better to start with a latest native image.
seifhd Posted November 11, 2018 Posted November 11, 2018 In theory, if you manage to install those packages
