rufik Posted July 30, 2018 Posted July 30, 2018 I've just tried to build my custom image for OPI 2 but got into some trouble with space: Reveal hidden contents [ o.k. ] Preparing image file for rootfs [ orangepi2 xenial ] [ o.k. ] Current rootfs size [ 753 MiB ] [ o.k. ] Creating blank image for rootfs [ 872 MiB ] 872MiB [42,5MiB/s] [===========================================================================================================================================>] 100% [ o.k. ] Creating partitions [ root: ext4 ] [ .... ] Creating rootfs [ ext4 ] [ .... ] Copying files to root directory 657.56M 99% 25.52MB/s 0:00:24 (xfr#44298, to-chk=4/56213) rsync: mkstemp "/home/rufik/workspace/armbian/.tmp/mount-next-orangepi2-xenial-no/var/lib/dpkg/info/.libtext-wrapi18n-perl.list.s6O3ub" failed: No space left on device (28) rsync: mkstemp "/home/rufik/workspace/armbian/.tmp/mount-next-orangepi2-xenial-no/var/lib/dpkg/info/.libtext-wrapi18n-perl.md5sums.rlQNhJ" failed: No space left on device (28) [... a lot of files failures...] rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2] [ o.k. ] Free space: [ SD card ] Filesystem Size Used Avail Use% Mounted on udev 1,9G 0 1,9G 0% /dev tmpfs 395M 1,3M 393M 1% /run /dev/sda2 49G 22G 25G 48% / tmpfs 2,0G 0 2,0G 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 2,0G 0 2,0G 0% /sys/fs/cgroup /dev/loop0 87M 87M 0 100% /snap/core/4917 /dev/loop1 3,8M 3,8M 0 100% /snap/gnome-system-monitor/51 /dev/loop2 21M 21M 0 100% /snap/gnome-logs/25 /dev/loop3 2,4M 2,4M 0 100% /snap/gnome-calculator/180 /dev/loop4 13M 13M 0 100% /snap/gnome-characters/103 /dev/loop5 141M 141M 0 100% /snap/gnome-3-26-1604/70 /dev/loop6 141M 141M 0 100% /snap/gnome-3-26-1604/59 /dev/loop7 1,7M 1,7M 0 100% /snap/gnome-calculator/154 /dev/loop8 3,4M 3,4M 0 100% /snap/gnome-system-monitor/36 /dev/loop9 13M 13M 0 100% /snap/gnome-characters/69 /dev/loop10 15M 15M 0 100% /snap/gnome-logs/37 /dev/loop11 87M 87M 0 100% /snap/core/4486 /dev/sda1 511M 4,7M 507M 1% /boot/efi Temp 230G 181G 50G 79% /media/sf_Temp tmpfs 395M 40K 395M 1% /run/user/1000 tmpfs 2,6G 753M 1,9G 29% /home/rufik/workspace/armbian/.tmp/rootfs-next-orangepi2-xenial-no /dev/loop12p1 839M 752M 54M 94% /home/rufik/workspace/armbian/.tmp/mount-next-orangepi2-xenial-no [ o.k. ] Writing U-boot bootloader [ /dev/loop12 ] [ o.k. ] Done building [ /home/rufik/workspace/armbian/output/images/Armbian_5.54_Orangepi2_Ubuntu_xenial_next_4.17.11.img ] [ o.k. ] Runtime [ 50 min ] I'm not really short of root fs space. It looks like /dev/loop12p1 lacks of free space. Why? Should I adjust this loop device size somehow? I'm building on Ubuntu 18.04.
Igor Posted July 30, 2018 Posted July 30, 2018 On 7/30/2018 at 1:34 PM, rufik said: I'm building on Ubuntu 18.04. Expand Are you adding/changing anything?
rufik Posted July 30, 2018 Author Posted July 30, 2018 On 7/30/2018 at 2:19 PM, Igor said: Are you adding/changing anything? Expand Yup, midnight commander via apt-get On 7/30/2018 at 3:07 PM, Igor said: Retry now. Expand Thanks, I just found this place to be adjusted.
Igor Posted July 31, 2018 Posted July 31, 2018 On 7/30/2018 at 5:26 PM, rufik said: Thanks, I just found this place to be adjusted. Expand Is it O.K. now?
rufik Posted July 31, 2018 Author Posted July 31, 2018 On 7/31/2018 at 2:06 PM, Igor said: Is it O.K. now? I didn't test directly your value (1.20), I set it to 2.0 because of my customization I'm preparing - it works fine. I suppose it should be OK.
Igor Posted July 31, 2018 Posted July 31, 2018 On 7/31/2018 at 2:21 PM, rufik said: I didn't test directly your value (1.20), I set it to 2.0 because of my customization I'm preparing - it works fine. I suppose it should be OK. Expand OK. BTW. 2 is overkill
