Hello all,
i wonder what is the status of the support for this touchcontroller.
I've got to know that in latest kernels there is prebuilt support for it and in my latest armbian there is a module for this. But following this:
https://www.raspberrypi.org/forums/viewtopic.php?t=143581
i failed to make it work. May be i've done it the wrong way in armbianEnv.txt tho.
Should i just insert theese line into this file?
dtparam=i2c_arm=on
dtparam=spi=on
dtoverlay=ads7846,penirq=25,speed=10000,penirq_pull=2,xohms=150
According to dmesg log, module is loading, but nothing happens when i touch the screen.
If not, should i instead use methods that suggest compiling this driver?
https://sourceforge.net/p/openipmi/linux-ipmi/ci/master/tree/drivers/input/touchscreen/ads7846.c
I've made my tft working relatively easily, but now i seem to completely stuck.
Are you using 4.17.y or 4.14.y kernel? In 4.17.y this might not work properly yet.
i'm on 4.14 tho. can you confirm that i can simply copy those device tree lines to armbianEnv.txt without changes? i'm not sure here, but don't know the right answer.
Not that copy/paste simple. Check this generic DT manual https://docs.armbian.com/User-Guide_Allwinner_overlays/. Do some extensive search with www.armbian.com/search since its possible that someone already succeed in this. I don't deal much with those displays to give you the straight answer but I guess it should be possible to set it up.
