Odroid C2 freezing after upgrade
Heimdall
Hi guys,
After some time I get enough brave to do apt upgrade on my Odroid C2 (after month or two).. I updated following packages:
Start-Date: 2018-08-07  11:09:56
Commandline: apt upgrade
Install: html2text:arm64 (1.3.2a-18, automatic), debconf-utils:arm64 (1.5.56+deb8u1, automatic)
Upgrade: ncurses-term:arm64 (5.9+20140913-1+deb8u2, 5.9+20140913-1+deb8u3), libtinfo5:arm64 (5.9+20140913-1+deb8u2, 5.9+20140913-1+deb8u3), linux-dtb-odroidc2:arm64 (5.40, 5.54), libncurses5:arm64 (5.9+20140913-1+deb8u2, 5.9+20140913-1+deb8u3), libncursesw5:arm64 (5.9+20140913-1+deb8u2, 5.9+20140913-1+deb8u3), ncurses-bin:arm64 (5.9+20140913-1+deb8u2, 5.9+20140913-1+deb8u3), base-files:arm64 (8+deb8u10, 8+deb8u11), patch:arm64 (2.7.5-1, 2.7.5-1+deb8u1), libldap-2.4-2:arm64 (2.4.40+dfsg-1+deb8u3, 2.4.40+dfsg-1+deb8u4), linux-image-odroidc2:arm64 (5.40, 5.54), armbian-config:arm64 (5.40, 5.54), linux-u-boot-odroidc2-default:arm64 (5.40, 5.49), docker-ce:arm64 (18.05.0~ce~2.1.rc1-0~debian, 18.06.0~ce~2.1.rc1-0~debian), armbian-tools-jessie:arm64 (5.40, 5.44), tzdata:arm64 (2018d-0+deb8u1, 2018e-0+deb8u1), armbian-firmware:arm64 (5.40, 5.45), ncurses-base:arm64 (5.9+20140913-1+deb8u2, 5.9+20140913-1+deb8u3)
End-Date: 2018-08-07  11:10:45
After upgrade I am having freeze almost every 12 hours - not able to connect to the odroid via SSH (running headless) and I have to replug power (I am using official power adapter from Odroid via jack).
Here is link to logs etc. any ideas what it could be? I will try to set up nmon or zabbix to monitor health of mem / cpu before crash.
We proceeded to 3.16.y kernel as did the Hardkernel. Nothing interesting in the kernel commit logs: https://github.com/hardkernel/linux/commits/odroidc2-v3.16.y our build is very recent so it is virtually the same.
Can you check 4.14.y/4.17.y kernels? For that, you need to change u-boot and boot scripts. They are getting to that state, where we could just forget about old legacy kernels. Soon.
What is your use case?
47 minutes ago, Heimdall said:
I found option to upgrade kernel from armbian-config, but after upgrade to next kernel, after reboot is just green screen on HDMI and nothing else.. going to try clean next installation..
This problem was fixed with this commit but haven't got its way to the repository yet.
I just installed clean image (its not a big deal, since data are on external USB disc), but I am not able now to get disk even detected in system (its not even blinking), but this was working correctly on 3.16 kernel.. any ideas? I created logs where I can see, that USB hub is detected, but when I put USB disk on, nothing (in dmesg or messages) - http://ix.io/1jSw
Not even keyboard + mouse which I have in powered USB hub is loaded.. not a single line in dmesg after connection (tested all 4 ports).
Don´t know if this can be named as "They are getting to that state, where we could just forget about old legacy kernels." :-)
10 minutes ago, Heimdall said:
Heh, this kind of commits should be in repo asap
Getting to the main repository needs general testing. It's not the only thing that has been changed. Until we are running this project on a hobby level ... it has to wait. Barbecue has higher priority :P
And any ideas about USB problems in following post?
USB generally works but sometimes hotplugging doesn't work. Reboot helps and latest changes regarding USB are probably not in the stable repo ... they are for sure in beta/nightly.
Nope, reboot was first what I was trying.. mkey, back to 3.16 and I will write to my forehead "ARM boards are not worth it.. x86 ftw" (but I am glad what you and whole Armbian team doing, but support from ARM producers is shitty unfortunately).
6
Comparing experimental mainline support on certain cheap ARM hardware vs. mainstream x86 is pointless. ARM boards are chosen by a use case in first place.  If you want a modern kernel, certain things will simply not work. USB must work and it should. This (and usually network) is a minimum level that we start to provide test support. For certain uses cases, this is already good enough.
Since ATM I can't check if the latest update actually broke USB I can't argue about. USB used to work on a modern kernel with a few limitations ...
ARM corp. only creates a design which is licensed to chip makers. Chip on C2 was made in Amlogic corp., which helps the community develop mainline kernel support via this project http://linux-meson.com/doku.php I hope they(Amlogic)  are not underestimating the scale of this process ... which takes months to years per chip family. We are more on the implementation, testing and maintenance side in this process.
I made a few tests and you can see below that USB is working all the time.
[    3.810953] scsi 0:0:0:0: Direct-Access     Multiple Card  Reader     1.00 PQ: 0 ANSI: 0
[    4.015361] random: crng init done
[    4.015376] random: 7 urandom warning(s) missed due to ratelimiting
[    4.366231] sd 0:0:0:0: [sda] 15269888 512-byte logical blocks: (7.82 GB/7.28 GiB)
[    4.367109] sd 0:0:0:0: [sda] Write Protect is off
[    4.367148] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[    4.367938] sd 0:0:0:0: [sda] No Caching mode page found
[    4.367962] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.374477]  sda: sda1
Nightly builds upgrade testing:
Odroid C2
http://ix.io/1jU0
Odroid XU4, started with oldest Ubuntu Xenial, kernel 3.10.y
-> NEXT -> DEV -> DEFAULT -> NEXT
http://ix.io/1jU1
XU4 ran from eMMC
I found few problems which needs to be fixed before sending out a new update ...
That´s for long discussion, but computer (some intel nuc like) for 130€ will be in the end better for me (if I count spent hours with problems) then Odroid for 100€ :) But when I was buying Odroid at release, I was hoping for great support, but actually, Hardkernel doesnt care too much about C2. It suprise me that about XU4/MC1/HC1/HC2 they care much more :)
And I want just headless server. I am not talking about some ARM for Kodi, because that is also not so well developed.. so for headleass.. do I want too much? :)
Odroid C2
http://ix.io/1jU0
http://ix.io/1jU1
XU4 ran from eMMC
Interesting, for me it was not working on clean NEXT installation. With default (3.16) kernel it works well.. with clean installation also system is stable now and not crashing every 12 hours :)
