Please help me to understand. When you install, it references incorrect versions of packages.
root@DOM:/etc/apt/sources.list.d# sudo apt-get install mosquitto
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 mosquitto : Depends: libssl1.0.0 (>= 1.0.0) but it is not installable
             Depends: libwebsockets3 (>= 1.2) but it is not installable
E: Unable to correct problems, you have held broken packages.
How can this be corrected?
info
BOARD=orangepiplus
BOARD_NAME="Orange Pi+"
BOARDFAMILY=sun8i
VERSION=5.38
LINUXFAMILY=sunxi
BRANCH=next
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
Thanks for the reply. But I put on a clean аssembly, has not had time to break anything:). Went through the options for correction, but nothing helps... To try to start again with a "clean slate"?
Did you edit your /etc/apt/sources.list or did you add additionally any sources?
Which armbian do you use (do you use a armbian distro? - because I never had problems with the sources of armbian)
What do you get for a message after?:
sudo apt autoremove && sudo apt autoclean && sudo apt clean
sudo apt-get update
sudo apt-get -f install
sudo apt-get install mosquitto mosquitto-clients
Edited by Tido
changed to one-liner for cleaning, update
On 8/12/2018 at 10:39 PM, Tido said:
do: armbianmonitor - u
Thank you!! But nothing useful happens when you run this command:). Or doing something wrong...
root@DOM:/home/orangepi# do: armbianmonitor - u
Could not find the database of available applications, run update-command-not-found as root to fix this
do:: command not found
sudo apt-get update
Thank you too:). Cleaned dependencies, nothing has changed, but suggested that it is necessary to remove all third-party repositories))). It worked)
Openhab2 may also need to put in the repository Arabian?)
Everything worked. I needed to use the Arabian repository and learn English:).  This topic can be closed.
