in the company where I work, a nanopi M1 plus was purchased and we are developing a firmware to run on the device. In our code we need to change the settings of the active wired connection at that time, but we can not do it due to an error. If, for example, we use the following command:
nmcli connection modify 'Ifupdown (eth0)' ipv4.method auto
The following error message is returned.
Error: failed to modify connection 'Ifupdown (eth0)': Connection is read-only
The command is executed correctly if the connection is not managed by NetworkManager, so when in the file: "NetworkManager.conf" the "managed" parameter is set to false. We had to set it to true because otherwise, by changing the ethernet cable and inserting another of another subnet, we realized that the device keeps the old IP address and therefore is unreachable. So how could we solve that problem?
Regards
Marco
I solved the problem by removing all the references to the wired connection from the "/etc/network/interfaces" file and creating one in NetworkManager.  Clearly I set the "managed" parameter to "false" in NetworkManager.conf
Regards
Marco
