 I compared two boards (opi zero h3 and opi zero plus  h5) and found that  cpu pins for 26 gpio are the same .
so I modify the code in wiringPi  about cpu detection to force return true value .
and it works.
the step:
1. git clone https://github.com/xpertsavenue/WiringOP-Zero
2. modify the code in  WiringOP-Zero/wiringPi/wiringPi.c  (or using the  attached file to replace)。
3. make  && make install
4.  run "gpio readall "  to test
5.  run "gpio write 30 1"    (the red-led on, wiringpi pin 30 control red-led status).
wiringPi.c
I used the wiringPi.c above, and
from make I get some error:
root@orangepizeroplus:/home/pi/WiringOP-Zero# make
ds1302.c:30:10: fatal error: wiringPi.h: No such file or directory
 #include <wiringPi.h>
compilation terminated.
Makefile:67: recipe for target 'ds1302.o' failed
make[1]: *** [ds1302.o] Error 1
instead of "make and make install"  I use:
chmod +x ./build
sudo ./build
this finish without an error
and the gpio`s are working well
thanks greetings
