DBB Posted September 5, 2018 Posted September 5, 2018 Hi I have added some drivers in the kernel source code in the cache folder and I am not sure how to rebuild the kernel with the new changes. I am trying to rebuild the mainline kernel. Using compile.sh overwrites the changes with default files. I have changed the following configurations in my config file. KERNEL_ONLY="no" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt 3 KERNEL_CONFIGURE="no" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt 4 CLEAN_LEVEL="" # comma-separated list of clean targets: "make" = make clean for selec 5 # "debs" = delete packages in "./output/debs" for current branch and family, 6 # "alldebs" = delete all packages in "./output/debs", "images" = delete "./output/imag 7 # "cache" = delete "./output/cache", "sources" = delete "./sources" 8 # "oldcache" = remove old cached rootfs except for the newest 8 files 9 10 DEST_LANG="en_US.UTF-8" # sl_SI.UTF-8, en_US.UTF-8 11 12 # advanced 13 KERNEL_KEEP_CONFIG="yes" # do not overwrite kernel config before compilation 14 EXTERNAL="yes" # build and install extra applications and drivers 15 EXTERNAL_NEW="prebuilt" # compile and install or install prebuilt additional packages 16 CREATE_PATCHES="no" # wait that you make changes to uboot and kernel source and creates patches 17 BUILD_ALL="no" # cycle through available boards and make images or kernel/u-boot packages. 18 # set KERNEL_ONLY to "yes" or "no" to build all packages/all images 19 20 BSPFREEZE="" # freeze armbian packages (u-boot, kernel, dtb) 21 INSTALL_HEADERS="" # install kernel headers package 22 LIB_TAG="master" # change to "branchname" to use any branch currently available. 23 CARD_DEVICE="" # device name /dev/sdx of your SD card to burn directly to the card when done I have removed clean so as to make it an incremental build. I am trying to build these changes in tree to test some quick changes.
Igor Posted September 6, 2018 Posted September 6, 2018 10 hours ago, DBB said: CREATE_PATCHES="yes" ... and add changes to the source code when asked. This way a patch is created and you can use it later when building.
DBB Posted September 7, 2018 Author Posted September 7, 2018 HI Igor 18 hours ago, Igor said: ... and add changes to the source code when asked. This way a patch is created and you can use it later when building. Hi Igor Thank you for the reply. I tried enabling CREATE_PATCHES in the config file. Still the compilation goes all the way through. I have attached the output printed by the script [ o.k. ] Downloading sources [ o.k. ] Checking git sources [ u-boot v2018.05 ] [ .... ] Up to date [ o.k. ] Checking git sources [ linux-mainline linux-4.14.y ] [ .... ] Up to date [ o.k. ] Checking git sources [ sunxi-tools master ] [ .... ] Up to date [ o.k. ] Checking git sources [ rkbin-tools master ] [ .... ] Up to date [ o.k. ] Checking git sources [ marvell-tools A3700_utils-armada-17.10 ] [ .... ] Up to date [ o.k. ] Checking git sources [ odroidc2-blobs master ] [ .... ] Up to date [ o.k. ] Checking git sources [ testing-reports master ] [ .... ] Fetching updates remote: Counting objects: 4, done. remote: Compressing objects: 100% (4/4), done. remote: Total 4 (delta 1), reused 2 (delta 0), pack-reused 0 Unpacking objects: 100% (4/4), done. From https://github.com/armbian/testings * branch master -> FETCH_HEAD + 21ed836...cb03e73 master -> origin/master (forced update) [ .... ] Checking out [ o.k. ] Starting rootfs and image building process for [ orangepizero xenial ] [ o.k. ] Extracting xenial-ng-armhf.113...912.tar.lz4 [ 2 days old ] xenial-ng-armhf.113...912.tar.lz4: 297MiB [24.6MiB/s] [=============================================================================================================================================>] 100% [ o.k. ] Applying distribution specific tweaks for [ xenial ] [ o.k. ] Applying common tweaks [ .... ] Installing [ linux-image-next-sunxi_5.59_armhf.deb ] [ .... ] Installing [ linux-u-boot-next-orangepizero_5.59_armhf.deb ] [ .... ] Installing [ linux-dtb-next-sunxi_5.59_armhf.deb ] [ .... ] Installing [ linux-xenial-root-next-orangepizero_5.59_armhf.deb ] [ o.k. ] Installing extra applications and drivers Reading package lists... Building dependency tree... Reading state information... expect is already the newest version (5.45-7). iperf3 is already the newest version (3.0.11-1). The following additional packages will be installed: libassuan0 libksba8 libnpth0 The following NEW packages will be installed: debconf-utils dirmngr html2text libassuan0 libksba8 libnpth0 0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded. Need to get 450 kB of archives. After this operation, 1,049 kB of additional disk space will be used. Err:1 http://ports.ubuntu.com xenial/universe armhf debconf-utils all 1.5.58ubuntu1 Could not resolve 'ports.ubuntu.com' Err:2 http://ports.ubuntu.com xenial/main armhf libassuan0 armhf 2.4.2-2 Could not resolve 'ports.ubuntu.com' Ign:3 http://ports.ubuntu.com xenial-updates/main armhf libksba8 armhf 1.3.3-1ubuntu0.16.04.1 Err:4 http://ports.ubuntu.com xenial/main armhf libnpth0 armhf 1.2-3 Could not resolve 'ports.ubuntu.com' Ign:5 http://ports.ubuntu.com xenial-updates/main armhf dirmngr armhf 2.1.11-6ubuntu2.1 Err:6 http://ports.ubuntu.com xenial/universe armhf html2text armhf 1.3.2a-18 Could not resolve 'ports.ubuntu.com' Err:3 http://ports.ubuntu.com xenial-updates/main armhf libksba8 armhf 1.3.3-1ubuntu0.16.04.1 Could not resolve 'ports.ubuntu.com' Err:5 http://ports.ubuntu.com xenial-updates/main armhf dirmngr armhf 2.1.11-6ubuntu2.1 Could not resolve 'ports.ubuntu.com' E: Failed to fetch http://ports.ubuntu.com/pool/universe/d/debconf/debconf-utils_1.5.58ubuntu1_all.deb Could not resolve 'ports.ubuntu.com' E: Failed to fetch http://ports.ubuntu.com/pool/main/liba/libassuan/libassuan0_2.4.2-2_armhf.deb Could not resolve 'ports.ubuntu.com' E: Failed to fetch http://ports.ubuntu.com/pool/main/libk/libksba/libksba8_1.3.3-1ubuntu0.16.04.1_armhf.deb Could not resolve 'ports.ubuntu.com' E: Failed to fetch http://ports.ubuntu.com/pool/main/n/npth/libnpth0_1.2-3_armhf.deb Could not resolve 'ports.ubuntu.com' E: Failed to fetch http://ports.ubuntu.com/pool/main/g/gnupg2/dirmngr_2.1.11-6ubuntu2.1_armhf.deb Could not resolve 'ports.ubuntu.com' E: Failed to fetch http://ports.ubuntu.com/pool/universe/h/html2text/html2text_1.3.2a-18_armhf.deb Could not resolve 'ports.ubuntu.com' E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? [ .... ] Installing [ armbian-config_5.59_all.deb ] [ .... ] Installing [ armbian-firmware_5.59_all.deb ] [ .... ] Installing [ armbian-tools-xenial_5.59_armhf.deb ] [ .... ] Installing additional packages [ EXTERNAL_NEW ] Hit:1 http://ports.ubuntu.com xenial InRelease Get:2 http://ports.ubuntu.com xenial-security InRelease [107 kB] Hit:3 http://apt.armbian.com xenial InRelease Get:4 http://ports.ubuntu.com xenial-updates InRelease [109 kB] Get:5 http://ports.ubuntu.com xenial-backports InRelease [107 kB] Get:6 http://ports.ubuntu.com xenial-security/main armhf Packages [532 kB] Get:7 http://ports.ubuntu.com xenial-security/universe armhf Packages [389 kB] Get:8 http://ports.ubuntu.com xenial-updates/main armhf Packages [895 kB] Get:9 http://ports.ubuntu.com xenial-updates/universe armhf Packages [769 kB] Fetched 2,908 kB in 52s (55.2 kB/s) Reading package lists... Reading package lists... Building dependency tree... Reading state information... hostapd is already the newest version (2:2.6-4~armbian5.38+1). You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: armbian-config : Depends: debconf-utils but it is not going to be installed Depends: html2text but it is not going to be installed Depends: html2text but it is not going to be installed Depends: dirmngr but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). [ o.k. ] Calling image customization script [ customize-image.sh ] [ o.k. ] Preparing image file for rootfs [ orangepizero xenial ] [ o.k. ] Current rootfs size [ 674 MiB ] [ o.k. ] Creating blank image for rootfs [ 816 MiB ] 816MiB [43.8MiB/s] [================================================================================================================================================================================>] 100% [ o.k. ] Creating partitions [ root: ext4 ] [ .... ] Creating rootfs [ ext4 on /dev/loop13p1 ] [ .... ] Updating initramfs... [ update-initramfs -uv -k 4.14.67-sunxi ] [ o.k. ] Updated initramfs. [ for details see: /home/dhaval/build/output/debug/install.log ] [ .... ] Copying files to root directory 610.98M 99% 27.67MB/s 0:00:21 (xfr#27264, to-chk=0/34645) sent 613.08M bytes received 548.89K bytes 28.54M bytes/sec total size is 615.80M speedup is 1.00 [ .... ] Copying files to /boot directory 26.33M 99% 68.53MB/s 0:00:00 (xfr#206, to-chk=0/213) sent 26.35M bytes received 3.96K bytes 52.71M bytes/sec total size is 26.33M speedup is 1.00 [ o.k. ] Free space: [ SD card ] Filesystem Size Used Avail Use% Mounted on udev 5.3G 0 5.3G 0% /dev tmpfs 1.1G 1.4M 1.1G 1% /run /dev/sda1 157G 32G 117G 22% / tmpfs 5.3G 0 5.3G 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 5.3G 0 5.3G 0% /sys/fs/cgroup /dev/loop0 15M 15M 0 100% /snap/gnome-logs/37 /dev/loop5 35M 35M 0 100% /snap/gtk-common-themes/319 /dev/loop1 3.8M 3.8M 0 100% /snap/gnome-system-monitor/51 /dev/loop4 2.4M 2.4M 0 100% /snap/gnome-calculator/180 /dev/loop2 88M 88M 0 100% /snap/core/5328 /dev/loop3 87M 87M 0 100% /snap/core/4917 /dev/loop7 141M 141M 0 100% /snap/gnome-3-26-1604/70 /dev/loop6 13M 13M 0 100% /snap/gnome-characters/103 /dev/loop9 15M 15M 0 100% /snap/gnome-logs/40 /dev/loop8 87M 87M 0 100% /snap/core/5145 /dev/loop10 3.8M 3.8M 0 100% /snap/gnome-system-monitor/54 /dev/loop11 13M 13M 0 100% /snap/gnome-characters/117 /dev/loop12 2.4M 2.4M 0 100% /snap/gnome-calculator/199 Ubuntu_18_Shared_Folder 477G 178G 299G 38% /media/sf_Ubuntu_18_Shared_Folder tmpfs 1.1G 24K 1.1G 1% /run/user/1000 /dev/sr0 56M 56M 0 100% /media/dhaval/VBox_GAs_5.2.12 tmpfs 7.1G 674M 6.4G 10% /home/dhaval/build/.tmp/rootfs-next-orangepizero-xenial-no /dev/loop13p1 784M 687M 65M 92% /home/dhaval/build/.tmp/mount-next-orangepizero-xenial-no [ o.k. ] Writing U-boot bootloader [ /dev/loop13 ] [ o.k. ] Done building [ /home/dhaval/build/output/images/Armbian_5.59_Orangepizero_Ubuntu_xenial_next_4.14.67.img ] [ o.k. ] Runtime [ 16 min ]
Igor Posted September 7, 2018 Posted September 7, 2018 5 hours ago, DBB said: Still the compilation goes all the way through. Because kernel was already compiled - it is cached and you obviously don't clean the cache (default is on). It also looks like your fs cache is corrupted due to network problems ... remove cache/rootfs or add ",cache" to the line below: You are missing this: CLEAN_LEVEL="make,debs,oldcache" Please take some time and study the manual.
vtrandal Posted November 25, 2018 Posted November 25, 2018 On 9/6/2018 at 11:25 PM, Igor said: Because kernel was already compiled - it is cached and you obviously don't clean the cache (default is on). It also looks like your fs cache is corrupted due to network problems ... remove cache/rootfs or add ",cache" to the line below: You are missing this: CLEAN_LEVEL="make,debs,oldcache" Please take some time and study the manual. <== What manual? This one? https://docs.armbian.com/Developer-Guide_Build-Options/
