madurani Posted September 7, 2018 Share Posted September 7, 2018 (edited) Hello, Could you please somebody advise me with hostapd issue? I installed on new Orange Pi R1 new Armbian: ARMBIAN 5.59 testing Debian GNU/Linux 9 (stretch) 4.14.65-sunxi Problem is, that after starting service hostapd system/kernel crashed Some short time is Access Point reachable, but then orange crashed. root@orangepi:~# cat /etc/hostapd/hostapd.conf interface=wlan0 bridge=br0 #driver=nl80211 ssid=Rubikon hw_mode=g channel=8 wmm_enabled=0 macaddr_acl=0 auth_algs=1 ignore_broadcast_ssid=0 wpa=2 wpa_passphrase=xxxxxxxxxxxxxx wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP root@orangepi:~# cat /etc/network/interfaces auto br0 iface br0 inet static bridge_ports enxc0742bffed69 wlan0 address 192.168.100.1 netmask 255.255.255.0 auto enxc0742bffed69 allow-hotplug enxc0742bffed69 iface enxc0742bffed69 inet manual auto wlan0 allow-hotplug wlan0 iface wlan0 inet manual wireless-power off Here is message from screen after crashing of kernel: Message from syslogd@localhost at Sep 7 19:03:18 ... kernel:[ 117.629526] Internal error: Oops: 5 [#1] SMP THUMB2 Message from syslogd@localhost at Sep 7 19:03:18 ... kernel:[ 117.736098] Process RTW_CMD_THREAD (pid: 1060, stack limit = 0xcadee210) Message from syslogd@localhost at Sep 7 19:03:18 ... kernel:[ 117.742843] Stack: (0xcadeff28 to 0xcadf0000) Message from syslogd@localhost at Sep 7 19:03:18 ... kernel:[ 117.747258] ff20: caa9e140 d1248000 d1249520 d1248000 ca30a200 bfb88040 Edited September 7, 2018 by madurani Link to comment Share on other sites More sharing options...
Igor Posted September 7, 2018 Share Posted September 7, 2018 In case of troubles try with modern kernel even it might lack some functionality. It is very simple: armbian-config -> switch to nightly, then choose alternative kernel DEV Link to comment Share on other sites More sharing options...
madurani Posted September 7, 2018 Author Share Posted September 7, 2018 8 minutes ago, Igor said: In case of troubles try with modern kernel even it might lack some functionality. It is very simple: armbian-config -> switch to nightly, then choose alternative kernel DEV Could you please provide me more details, because with armbian I work only half day? Link to comment Share on other sites More sharing options...
madurani Posted September 7, 2018 Author Share Posted September 7, 2018 14 minutes ago, Igor said: In case of troubles try with modern kernel even it might lack some functionality. It is very simple: armbian-config -> switch to nightly, then choose alternative kernel DEV I tried it and kernel was switched from 4.14.65-sunxi to 4.14.68-sunxi, but problem persist. But I am not sure whether I correct use tool armbian-config, because I didn't get any possibility, only new kernel was installed automatically. Link to comment Share on other sites More sharing options...
Igor Posted September 7, 2018 Share Posted September 7, 2018 5 minutes ago, madurani said: I tried it and kernel was switched from 4.14.65-sunxi to 4.14.68-sunxi, but problem persist. Now read my post once again. It contains all you need to know/do - I am not sure it will help but its a good path. It is expensive to provide you those hints (triple in Friday night), but I am afraid I can't guide you hand by hand in real time ... please don't expect this kind of luxury. Next, you are most likely not the only one with this problem. We have a powerful search function. Use it. Get familiar with Armbian ... then try to get clues here. Link to comment Share on other sites More sharing options...
madurani Posted September 7, 2018 Author Share Posted September 7, 2018 1 hour ago, Igor said: Now read my post once again. It contains all you need to know/do - I am not sure it will help but its a good path. It is expensive to provide you those hints (triple in Friday night), but I am afraid I can't guide you hand by hand in real time ... please don't expect this kind of luxury. Next, you are most likely not the only one with this problem. We have a powerful search function. Use it. Get familiar with Armbian ... then try to get clues here. I tried configure wifi via armbian-config and after that, I only add wlan0 to bridge br0 manually with second network interface enxc0742bffed69 and look, that it work. Before system crashed immediately(after few seconds when hostapd started). now is hostapd up 15 minutes and look fine. 3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br0 state UP group default qlen 1000 4: enxc0742bffed69: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000 5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 I want configure router/firewall on this HW(Orange PI R1). Now I have configure it on Raspberry PI3, but there is only one network card integrated on board. thank 1 Link to comment Share on other sites More sharing options...
madurani Posted September 9, 2018 Author Share Posted September 9, 2018 Firewall/router was build and works fine, but I have some trouble with ppp0 device. After starting/rebooting system interface ppp0 doesn't start immediately, but after some short time, approximately 5-15 seconds and then it is OK. Problem is, that I don't know how to create/write correct service file for starting firewall script, which will wait/test until ppp0 device is up. I tried some things, but service started before ppp0 interface(don't wait till ppp0 is up). I need to add to service file some option for waiting on ppp0 device: root@kraken:~# cat /lib/systemd/system/fwbuilder.service [Unit] Description=Fwbuilder Wants=network-online.target BindsTo=sys-devices-virtual-net-ppp0.device After=network.target network-online.target sys-devices-virtual-net-ppp0.device [Install] WantedBy=multi-user.target WantedBy=network-online.target [Service] ExecStart=/etc/init.d/fwbuilder start #ExecStop=/etc/init.d/fwbuilder stop Here is status when service started before ppp0: root@kraken:~# systemctl status fwbuilder ● fwbuilder.service - Fwbuilder Loaded: loaded (/lib/systemd/system/fwbuilder.service; enabled; vendor preset: enabled) Active: inactive (dead) since Sun 2018-09-09 16:10:38 CEST; 57s ago Process: 1585 ExecStart=/etc/init.d/fwbuilder start (code=killed, signal=TERM) Main PID: 1585 (code=killed, signal=TERM) Sep 09 16:10:38 kraken systemd[1]: Started Fwbuilder. Sep 09 16:10:38 kraken systemd[1]: fwbuilder.service: Unit is bound to inactive unit sys-devices-virtual-net-ppp0.device. Stopping, too. Sep 09 16:10:38 kraken systemd[1]: Stopping Fwbuilder... Sep 09 16:10:38 kraken systemd[1]: Stopped Fwbuilder. And here is status when service started after ppp0: root@kraken:~# systemctl status fwbuilder ● fwbuilder.service - Fwbuilder Loaded: loaded (/lib/systemd/system/fwbuilder.service; enabled; vendor preset: enabled) Active: inactive (dead) since Sun 2018-09-09 16:07:11 CEST; 1min 35s ago Process: 1670 ExecStart=/etc/init.d/fwbuilder start (code=exited, status=0/SUCCESS) Main PID: 1670 (code=exited, status=0/SUCCESS) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 10 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 11 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 12 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 13 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 14 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 15 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 16 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Rule 17 (global) Sep 09 16:07:11 kraken fwbuilder[1670]: Running epilog script Sep 09 16:07:11 kraken fwbuilder[1670]: fwbuilder. Link to comment Share on other sites More sharing options...
madurani Posted September 9, 2018 Author Share Posted September 9, 2018 I found some solution, but isn't very clever. I add path to iptables script direct to file /etc/ppp/ip-up.d/0clampmss /firewall/kraken.fw script started as is expected, when ppp0 is UP. Link to comment Share on other sites More sharing options...
Jean-Marc Posted June 28, 2019 Share Posted June 28, 2019 (edited) I am running hostapd on orangepir1 on internal wifi with success. There is still one issue only on log file creation. Is seems not possible to have log with Armbian package ??My configuration is : Spoiler root@srv-orangepir1-150:~# uname -a Linux srv-orangepir1-150 4.19.38-sunxi #5.85 SMP Wed May 8 14:20:48 CEST 2019 armv7l GNU/Linux root@srv-orangepir1-150:~# dpkg -l |grep hostapd ii hostapd 3:2.7-99~armbian5.86+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator root@srv-orangepir1-150:~# dpkg -l |grep armbian ii armbian-firmware 5.83 all Linux firmware ii armbian-tools-stretch 5.83 armhf Armbian tools, Cubie bt utils ii sunxi-tools 1.4.2-2~armbian5.86+1 armhf tools for working with Allwinner (sunxi) ARM processors root@srv-orangepir1-150:~# cat /etc/default/hostapd | grep -v "#" | grep -v "^$" DAEMON_CONF_INTERFACE="" DAEMON_CONF_FILE="" DAEMON_CONF_INTERFACE="wlan-ap0," DAEMON_CONF_FILE="/etc/hostapd/hostapd.srv-orangepir1-150.wlan-ap0.conf" DAEMON_OPTS="-d -t -K -f /var/log/hostapd/hostapd.log " DAEMON_CONF="$DAEMON_CONF_FILE" root@srv-orangepir1-150:~# cat /etc/hostapd/hostapd.srv-orangepir1-150.wlan-ap0.conf | grep -v "#" | grep -v "^$" interface=wlan-ap0 bridge=br-wifi-test driver=nl80211 logger_syslog=255 logger_syslog_level=0 logger_stdout=-1 logger_stdout_level=-1 ssid=ap-srv-orangepir1-150 country_code=FR ieee80211d=1 hw_mode=g channel=12 auth_algs=1 ieee80211n=1 wpa=2 wpa_passphrase=;debian; wpa_key_mgmt=WPA-PSK rsn_pairwise=CCMP root@srv-orangepir1-150:~# /etc/init.d/hostapd restart [ ok ] Stopping advanced IEEE 802.11 management: hostapd. [ ok ] Starting advanced IEEE 802.11 management: hostapd. root@srv-orangepir1-150:~# ps auxww |grep hostapd root 14085 0.0 0.1 5012 296 ? Ss 19:35 0:00 /usr/sbin/hostapd -B -P /run/hostapd.pid -d -t -K -f /var/log/hostapd/hostapd.log /etc/hostapd/hostapd.srv-orangepir1-150.wlan-ap0.conf root 15111 0.0 0.2 4152 560 pts/0 S+ 19:43 0:00 grep hostapd root 22572 0.0 0.0 3440 56 pts/0 S 18:23 0:00 tail -f /var/log/hostapd/hostapd.log All jobs seems ok, but there is no log file .... So now, i remove hostapd (because installed by Armbian, and i reinstall hostapd from Debian stretch or stretch-backports. root@srv-orangepir1-150:~# apt install hostapd Lecture des listes de paquets... Fait Construction de l'arbre des dépendances Lecture des informations d'état... Fait The following additional packages will be installed: libnl-route-3-200 Les NOUVEAUX paquets suivants seront installés : hostapd libnl-route-3-200 0 mis à jour, 2 nouvellement installés, 0 à enlever et 1 non mis à jour. Il est nécessaire de prendre 608 ko dans les archives. Après cette opération, 1 294 ko d'espace disque supplémentaires seront utilisés. Souhaitez-vous continuer ? [O/n] O Réception de:1 http://ftp.debian.org/debian stretch/main armhf libnl-route-3-200 armhf 3.2.27-2 [115 kB] Réception de:2 http://security.debian.org stretch/updates/main armhf hostapd armhf 2:2.4-1+deb9u4 [493 kB] 608 ko réceptionnés en 0s (807 ko/s) Sélection du paquet libnl-route-3-200:armhf précédemment désélectionné. (Lecture de la base de données... 31602 fichiers et répertoires déjà installés.) Préparation du dépaquetage de .../libnl-route-3-200_3.2.27-2_armhf.deb ... Dépaquetage de libnl-route-3-200:armhf (3.2.27-2) ... Sélection du paquet hostapd précédemment désélectionné. Préparation du dépaquetage de .../hostapd_2%3a2.4-1+deb9u4_armhf.deb ... Dépaquetage de hostapd (2:2.4-1+deb9u4) ... Paramétrage de libnl-route-3-200:armhf (3.2.27-2) ... Traitement des actions différées (« triggers ») pour libc-bin (2.24-11+deb9u4) ... Traitement des actions différées (« triggers ») pour man-db (2.7.6.1-2) ... Paramétrage de hostapd (2:2.4-1+deb9u4) ... root@srv-orangepir1-150:~# And now log files are ok . As a result, because log file are mandatory for me to debug wifi issues, and in order to give always capabilities to install uboot and kernel from Armbian, i have blacklisted hostapd from Armbian in the preferences, so that all is now OK. My configuration is now : root@srv-orangepir1-150:~# cat /etc/logrotate.d/hostapd |grep -v "#" |grep -v "^$" /var/log/hostapd/hostapd.log { rotate 4 weekly minsize 1M size 1000k missingok create 0640 root grp_ssh_user notifempty compress delaycompress postrotate invoke-rc.d hostapd reload > /dev/null endscript daily } root@srv-orangepir1-150:~# ls -altr /etc/apt/sources.list.d/ total 36 drwxr-xr-x 6 root root 4096 juin 28 19:26 .. -rw-r--r-- 1 root root 1022 juin 28 19:26 debian_apt_v_9_stretch_previous.list -rw-r--r-- 1 root root 840 juin 28 19:27 debian_apt_v_9_stretch_current.list -rw-r--r-- 1 root root 850 juin 28 19:27 debian_apt_v_9_stretch_updates.list -rw-r--r-- 1 root root 908 juin 28 19:27 debian_apt_v_9_stretch_update_security.list -rw-r--r-- 1 root root 848 juin 28 19:27 debian_apt_v_9_stretch_backports.list -rw-r--r-- 1 root root 920 juin 28 19:27 debian_apt_v_9_stretch_next.list -rw-r--r-- 1 root root 839 juin 28 19:27 armbian_apt_v_9_stretch.list root@srv-orangepir1-150:~# cat /etc/apt/sources.list.d/*list|grep -v "#" |grep -v "^$" deb http://apt.armbian.com stretch main stretch-utils stretch-desktop deb http://ftp.fr.debian.org/debian stretch-backports main contrib non-free deb http://ftp.debian.org/debian/ stretch main contrib non-free deb http://ftp.debian.org/debian/ buster main contrib non-free deb http://security.debian.org stretch/updates main contrib non-free deb http://ftp.fr.debian.org/debian stretch-updates main contrib non-free root@srv-orangepir1-150:~# ls -altr /etc/apt/preferences.d/ total 24 drwxr-xr-x 6 root root 4096 juin 28 19:26 .. -rw-r--r-- 1 root root 1054 juin 28 19:27 preferences_debian_v_9_stretch_no_systemd.pref -rw-r--r-- 1 root root 2495 juin 28 19:27 preferences_debian_v_9_stretch.pref -rw-r--r-- 1 root root 1163 juin 28 19:27 preferences_debian_v_9_stretch_no_dhcpcd5.pref -rw-r--r-- 1 root root 1011 juin 28 19:27 preferences_armbian_stretch.pref drwxr-xr-x 2 root root 4096 juin 28 19:27 . root@srv-orangepir1-150:~# cat /etc/apt/preferences.d/preferences_armbian_stretch.pref |grep -v "#" |grep -v "^$" Package: hostapd Pin: origin "apt.armbian.com" Pin-Priority: -1 Package: * Pin: origin "apt.armbian.com" Pin-Priority: 500 All is ok now ... Thanks to Debian preferences (!) Edited June 30, 2019 by lanefu moved config data into spoiler Link to comment Share on other sites More sharing options...
