Vitor Hugo Posted September 11, 2018 Posted September 11, 2018 (edited) Hello everyone, I ask the help of you to identify which card is this. To download the correct image. Thank you Edited September 11, 2018 by Vitor Hugo adding better photos
botfap Posted September 11, 2018 Posted September 11, 2018 Looks like a Texas Instruments developer board of the type you find in cheap CCTV systems from the layout and headers What is it running currently? Any identifiable numbers? I could be wrong but I doubt there is an image pre baked for it
Vitor Hugo Posted September 11, 2018 Author Posted September 11, 2018 the only identification numbers that exist on the board are in photo number 2 "ML19U", "94v-0", "5011". But I can not find anything about it. Accessing the files through the computer found a directory /.disk/info With the content: "Ubuntu 12.04" Precise "- Build armhf LIVE Binary 20150911-21: 56 " I tried to download this image but I can not find it, the links are broken.
botfap Posted September 11, 2018 Posted September 11, 2018 The disk info is from an Ubuntu 12.04 live image for arm7 but that doesn’t really help this is not an armbian supported board you need to figure out what the board is before you can figure out if you can run or adapt armbian to run on it. At the very least you need to remove the heat shield and get the SoC numbers and id marks below it this is not the place to ask such a question as it has nothing to do with armbian. Your best bet is to identify the SoC first and use that as a starting point in the absence of any oem markings
guidol Posted September 11, 2018 Posted September 11, 2018 Its a Pandaboard - but you have to find out the correct revision of the board! https://elinux.org/PandaBoard here a look at the ES Revision, but they look the same for me: https://www.digikey.com/en/product-highlight/t/texas-instruments/pandaboard pandaboard.org seems to be offline (dark screen here), but here is a archive page: https://web.archive.org/web/20161219065244/http://pandaboard.org:80/content/resources/software debian for the Panda-board: https://wiki.debian.org/InstallingDebianOn/PandaBoard or Ubuntu: https://wiki.ubuntu.com/ARM/OmapDesktopInstall https://web.archive.org/web/20130721204429/http://omappedia.org/wiki/Ubuntu_Pre-Built_Binaries
Vitor Hugo Posted September 11, 2018 Author Posted September 11, 2018 Thank you a LOT! You help me very much! I'll study this 1
guidol Posted September 11, 2018 Posted September 11, 2018 PDFs https://course.ccs.neu.edu/cs4610/docs/Panda_Board_Spec_DOC-21010_REV0_6.pdf https://www.cs.utexas.edu/~simon/378/resources/PandaBoardES.pdf The company who did build your system was bad and blacked out the pandaboard-logo and on the backside of the pcb they did put a big sticker over the revision.... Maybe you could remove the black paint and their sticker to get YOUR revision.... because Rev ES There is now a PandaBoard-ES which includes an OMAP 4460 at up to 1.2GHz. Several important differences make it important (at the present time) that the MLO/u-boot/kernel be specifically crafted for the 4460. The thermal management is not in the mainline 4430 code as yet and could cause unwanted thermal problems. So BEWARE of running any code built for the non -ES PandaBoard on the -ES model. Non-ES Pandaboard got a OMAP4430 Application processor CPU
Vitor Hugo Posted September 11, 2018 Author Posted September 11, 2018 is with a tape, very fixed. I'm afraid to remove and damage the board. As I already know what board it is, I'm going to test the images that have passed me.
guidol Posted September 11, 2018 Posted September 11, 2018 4 minutes ago, Vitor Hugo said: As I already know what board it is, I'm going to test the images that have passed me. but be careful if you got a ES Revision not to overheat the CPU becaise of the missing control software/driver..... At first try the software for the OMAP4430 CPU-Type/revision
