schwar3kat Posted September 14, 2018 Posted September 14, 2018 I'm a newb, so please make allowances if I am a little dumb. I have SPI NOR boot working on an Orange Pi Zero Plus (H5). Latest next kernel. (I've tried the download, and compiled my own). There is a problem when I power on. It fails to detect the USB drive. If I reset the CPU it finds the drive. If I reboot it finds the drive. resetting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found I want to try some things in the boot environment settings, but I haven't figured out where to do this. Can anyone point me in the right direction to modify the environment for this board? I have a Vagrant build environment set up, so I can compile, but so far I haven't been able to find where these settings are configured
martinayotte Posted September 14, 2018 Posted September 14, 2018 That is probably due to the fact that your USB drive take a while to become ready... You probably need to try adding INITIAL_USB_SCAN_DELAY in u-boot config and recompile it ... https://lists.denx.de/pipermail/u-boot/2016-April/250343.html
Solution schwar3kat Posted September 15, 2018 Author Solution Posted September 15, 2018 Thanks martinayotte - it is working now. I'm describing this for other newbs who might struggle to find these things. Your referenced patch has pointed me to "arch/arm/mach-sunxi/usb_phy.c" which I found in my Vagrant build environment at "/home/vagrant/armbian/cache/sources/u-boot/<version>/" The line "static int initial_usb_scan_delay = CONFIG_INITIAL_USB_SCAN_DELAY;" exists so it looks like the referenced patch is now a part of the build. I found the u-boot configs under "/home/vagrant/armbian/cache/sources/u-boot/<version>/configs" and the one for my board is named "orangepizero_plus_defconfig" cd /home/vagrant/armbian sudo nano config-default.conf modify line CREATE_PATCHES="no" to CREATE_PATCHES="yes" ^X y enter to save sudo ./compile.sh Select your board then enter at the prompts until you reach: [ warn ] Make your changes in this directory: [ /home/vagrant/armbian/cache/sources/u-boot/] [ warn ] Press <Enter> after you are done [ waiting ] In a new session - (I used putty, I couldn't do it from the windows command prompt vagrant ssh ) cd /home/vagrant/armbian/cache/sources/u-boot/<version>/configs sudo nano orangepizero_plus_defconfig add a line CONFIG_INITIAL_USB_SCAN_DELAY=3000 ^X y enter to save Back to the original session press enter and answer all prompts until compile is complete. diff --git a/configs/orangepizero_plus_defconfig b/configs/orangepizero_plus_defconfig index 4298f1e..ef14bcb 100644 --- a/configs/orangepizero_plus_defconfig +++ b/configs/orangepizero_plus_defconfig @@ -20,3 +20,4 @@ CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_SD_BOOT=y +CONFIG_INITIAL_USB_SCAN_DELAY=3000 The patch will be in \vagrant\output\patch\u-boot-sunxi64-next.patch Don't be tempted to edit this file in windows. It will be corrupted by the line feeds.
TonyMac32 Posted September 16, 2018 Posted September 16, 2018 On 9/15/2018 at 2:38 AM, Elektrický said: Don't be tempted to edit this file in windows. It will be corrupted by the line feeds. * Don't use notepad to edit this file in Windows. Use Notepad++ or another adequate editor, the only ones adding linefeeds date back to MSDOS. It's not intrinsic to the operating system, it's editor-dependant.
