Sodrohu Posted September 19, 2018 Posted September 19, 2018 I've installed a bootable Armbian Ubuntu on an SD card. I plan to copy the SD's OS into multiple OPI PC+ devices. The problem I found was that somehow the HDMI monitor displays a different max resolution depending on which OPI device I'm using. The armbianEnv.txt for the SD card: verbosity=1 logo=disabled console=both #disp_mode=1920x1080p60 disp_mode=1280x720p60 overlay_prefix=sun8i-h3 rootdev=UUID=8bc771e4-1c8a-4bd0-af02-00570c63c5c9 rootfstype=ext4 overlays=uart1 uart2 uart3 extraargs=drm_kms_helper.edid_firmware=edid/1280x720.bin usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u When I boot the SD card on the OPIPC+ displaying the correct max resolution (1920x 720) , these settings are: xrandr --props: Screen 0: minimum 320 x 200, current 1280 x 720, maximum 8192 x 8192 HDMI-1 connected 1280x720+0+0 (normal left inverted right x axis y axis) 333mm x 187mm EDID: 00ffffffffffff0031d8000000000000 051601036d211278ea5ec0a4594a9825 20505400000081c00101010101010101 010101010101011d008051d01c204080 35004dbb1000001e000000ff004c696e 75782023300a20202020000000fd003b 3d2b2d08000a202020202020000000fc 004c696e75782048440a202020200094 non-desktop: 0 range: (0, 1) link-status: Good supported: Good, Bad 1280x720 59.65*+ When I boot the SD card on the The OPIPC+ displaying the wrong max resolution (1024x 768) has these settings: xrandr --props: Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192 HDMI-1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm non-desktop: 0 range: (0, 1) link-status: Good supported: Good, Bad 1024x768 60.00* 800x600 60.32 56.25 848x480 60.00 640x480 59.94 uname -a: Linux orangepipcplus 4.17.14-sunxi #9 SMP Mon Aug 13 09:06:31 +08 2018 armv7l armv7l armv7l GNU/Linux The OPICP+ with the wrong max address also currently had a pink screen issue with legacy Armbian images. That's why I changed to the new mainline kernel; to enable HDMI output. On both OPIPC+ devices the EMMC is flashed with Armbian Debian stretch mainline. On both devices the Debian displays the resolution properly (1920x720). I am currently trying to get the Ubuntu OS to work as well.
Igor Posted September 19, 2018 Posted September 19, 2018 On modern kernel, a resolution is autodetected. Ubuntu and Debian share exact same kernel and u-boot which means there is no diff at this level.
Sodrohu Posted September 19, 2018 Author Posted September 19, 2018 I thought that this might be a device issue, since 1 device (and some other devices I tested) loads the correct resolution regardless of which OS it booted from. Only 1 OPIPC+ so far had this issue. Quote On modern kernel, a resolution is autodetected. Ubuntu and Debian share exact same kernel and u-boot which means there is no diff at this level. If so, why then this one device displays proper on Debian, but had issues on Ubuntu? I suspect this is related to the pink screen issue but I've got no proof so far...
