Hey guys. I need your help. Since I'm new to linux I don't know what happened and what to do.
Latest armbian was installed on my eMMC.
Today at morning I woke up and logged in by ssh to my orange pi pc plus and get 'input/output error' for every single command. I've tried to reboot it by powering off and on and after that I could not log in by ssh. (and I noticed that green led not blinking and ethernet port green and orange LEDs was constantly on)
I've inserted 16gb SD card with latest armbian installed on it and it works by booting from it(green led is blinking, ethernet port LEDs are also blinking, everything is ok).
I've tried to list partitions and drives:
root@orangepipcplus:~# sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
NAME        FSTYPE  SIZE MOUNTPOINT LABEL
mmcblk0            14.9G
└─mmcblk0p1 ext4   14.9G /
zram0                50M /var/log
zram1               125M [SWAP]
zram2               125M [SWAP]
zram3               125M [SWAP]
zram4               125M [SWAP]
root@orangepipcplus:~# sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x14996962
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       8192 31116287 31108096 14.9G 83 Linux
Disk /dev/zram0: 50 MiB, 52428800 bytes, 12800 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 125 MiB, 131080192 bytes, 32002 sectors
Disk /dev/zram2: 125 MiB, 131080192 bytes, 32002 sectors
Disk /dev/zram3: 125 MiB, 131080192 bytes, 32002 sectors
Disk /dev/zram4: 125 MiB, 131080192 bytes, 32002 sectors
and also this: http://ix.io/1nOQ (here we can see that system still detect mmcblk1 for some reason)
pls help <3
sorry for my bad english
5 minutes ago, martinayotte said:
Did you tried to do a "fsck.ext4 /dev/mmcblk1p1" ?
root@orangepipcplus:~# fsck.ext4 /dev/mmcblk1p1
e2fsck 1.44.1 (24-Mar-2018)
fsck.ext4: No such file or directory while trying to open /dev/mmcblk1p1
Possibly non-existent device?
1 minute ago, martinayotte said:
What "dmesg | grep -i mmc" is showing ?
Maybe the eMMC is now completely dead ...
root@orangepipcplus:~# dmesg | grep -i mmc
[    0.000000] Kernel command line: root=UUID=1d000aec-4bfa-4c75-80fd-d3325d028c19 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=14996962-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    1.149647] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.173457] sunxi-mmc 1c0f000.mmc: base:0xf1005000 irq:25
[    1.198452] sunxi-mmc 1c11000.mmc: base:0xf100d000 irq:27
[    1.231051] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.234244] mmc0: new high speed SDHC card at address aaaa
[    1.234944] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[    1.236264]  mmcblk0: p1
[    2.082541] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    2.106529] sunxi-mmc 1c10000.mmc: base:0xf10e8000 irq:26
[    2.131226] mmc2: new high speed SDIO card at address 0001
[    2.879474] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    4.681498] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
It supposed to be like :
[    0.978123] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.003447] sunxi-mmc 1c0f000.mmc: base:0x(ptrval) irq:24
[    1.030083] sunxi-mmc 1c11000.mmc: base:0x(ptrval) irq:26
[    1.076172] mmc1: new DDR MMC card at address 0001
[    1.076776] mmcblk1: mmc1:0001 8WPD3R 7.28 GiB
[    1.077115] mmcblk1boot0: mmc1:0001 8WPD3R partition 1 4.00 MiB
[    1.077514] mmcblk1boot1: mmc1:0001 8WPD3R partition 2 4.00 MiB
[    1.079080]  mmcblk1: p1
Probalby dead, or cold/bad solderings ...
