Guest Posted September 30, 2018 Posted September 30, 2018 Hello, I'm using a BananaPi M1 board long time with armbian. Most of the other BananaPi boards are no longer supported with armbian. Which board will have the best change to armbian lts? I only need a board with 1GB RAM, 2 x USB, 1 x Gigabit Net, SATA for small home server settings. Any hint?
chwe Posted September 30, 2018 Posted September 30, 2018 That's not up to armbian to decide... If the boardmaker drops a board it might get dropped by armbian earlier. On 9/30/2018 at 2:46 PM, RSU said: SATA Expand be more specific here.. SATA over USB2 (e.g. max ~40mb/s) is sufficient? price range? some stuff worth to read: https://forum.armbian.com/forum/29-reviews/
guidol Posted September 30, 2018 Posted September 30, 2018 On 9/30/2018 at 2:46 PM, RSU said: Any hint? Expand As NAS the Hardkernel Odroid HC-1 (for 2.5") or HC-2 (for 3.5") seems to be for me a good choice at this time HC-1:https://www.hardkernel.com/main/products/prdt_info.php?g_code=G150229074080 HC-2:https://www.hardkernel.com/main/products/prdt_info.php?g_code=G151505170472 Armbian HC-1/HC-2:https://www.armbian.com/odroid-hc1/ 1
Guest Posted September 30, 2018 Posted September 30, 2018 Hi, ok... some more information. I need SATA just for one system 2.5" hdd/ssd. It is not used for NAS, I've a NAS server already on LAN. The board is connected to WAN and there is a web server (nginex) running, and also ftp/ssh server and vpn (client to my internet server). That's all. It is my outside connection to my LAN.
Mr.Grape Posted October 1, 2018 Posted October 1, 2018 On 9/30/2018 at 9:48 PM, RSU said: Hi, ok... some more information. I need SATA just for one system 2.5" hdd/ssd. It is not used for NAS, I've a NAS server already on LAN. The board is connected to WAN and there is a web server (nginex) running, and also ftp/ssh server and vpn (client to my internet server). That's all. It is my outside connection to my LAN. Expand Perhaps Odroid HC1 / HC2. For me, HC1 works as a mini general purpose server.
Guest Posted October 1, 2018 Posted October 1, 2018 Odroid HC1 seems to be a good solution for me and makes a good impression. Thanks for the hints!
Mr.Grape Posted October 1, 2018 Posted October 1, 2018 On 10/1/2018 at 12:43 PM, RSU said: Odroid HC1 seems to be a good solution for me and makes a good impression. Thanks for the hints! Expand If you finally decide on HC1, make sure you are up-to-date after the purchase.... https://wiki.odroid.com/odroid-xu4/software/jms578_fw_update https://wiki.odroid.com/odroid-xu4/troubleshooting/shutdown_script
