Access Point Ralink MT7601U (148f:7601) Wi-Fi on Ubuntu Bionic
I have an orange pi with installed Ubuntu Bionic mainline Linux orangepione 4.14.65-sunxi, I have to create an economic access point with the Ralink MT7601U device (148f: 7601) already in possession, from the original driver configuration mediatek this device does not work as accesspoint but turning the network I found drivers modified in github that allow me to enable it as an AP.
The driver of the newly installed distro is recognized as wlx00e1b0117ad1 but when I do iw list Supported interface modes:
managed
monitor
there is no AP in the list. If I do iw wlx00e1b0117ad1 scan find me other wifi networks.
One of the many guides I followed is https://github.com/muratdemirtas/MT7601u, but in the installation it gives me an error. following images with errors at the launch of the various commands.
lsusb cpmake ifconfig iwdev
How can I solve the problem, is there a way?
seems there was a small typo in armbian-config:
https://github.com/armbian/config/commit/ab7703a4519b9a720797806b6b720d0ab168e164
@Igor already fixed it, but I assume it needs a bit until the fix is available in apt.armbian.
I assume manual installation of the headers should do it:
wget https://apt.armbian.com/pool/main/l/linux-4.14.70-sunxi/linux-headers-next-sunxi_5.60_armhf.deb
sudo dpkg -i linux-headers-next-sunxi_5.60_armhf.deb
53 minutes ago, arx said:
this looks like https://github.com/armbian/testings and has nothing to do with kernel headers.. ;)
headers successfully installed but
I can not figure out when I'm going to install the modified drivers to allow the access point to enable me to make this mistake
moved to 'common issues' from here it's a issue not related to provided software by Armbian. Issues related to third party drivers should IMO be reported to their issue trackers.
