Hi team, I want to install a 3G USB modem from Huawei exactly the e173 one in a Nexbox A95X 1/8 TVBOX, I can see the modem is on modem mode  in lsusb, but I cant get work that modem. I can't see the serial ports that supposed to be in /dev/ directory, can you help me?
Edited by Ricardo Rodriguez Salinas
thanks for your quick response, sorry I'm new here I don't know how to write down in this kind of topics
I got installed this one
 ARMBIAN 5.60 user-built Ubuntu 18.04.1 LTS 4.18.7-aml-s9xxx
The modem is detected but I can't see the serial ports
root@A95X:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 12d1:1c05 Huawei Technologies Co., Ltd. Broadband stick (modem on)
root@A95X:~# ls -la /dev/ttyUSB*
ls: cannot access '/dev/ttyUSB*': No such file or directory
thanks
Maybe because it is appearing as other kind of devices, such /dev/ttyACM* ...
Check what "dmesg" is reporting, could be that specific driver is not present in this kernel ...
According to "dmesg" output, no driver is associated with USB insertion ...
Check the possibility of presence/absence of those kernel configs :
grep USB_SERIAL_OPTION /boot/config-*
grep USB_NET_QMI_WWAN /boot/config-*
grep CONFIG_USB_NET_HUAWEI_CDC_NCM /boot/config-*
I am also facing an issue in my 3G modem serial ports,  I think it is COM Port Selection related issue.
Error is "Device connected, Serial open failed". Can anyone guide me, that how can I resolve this issue.?
  • Werner locked this topic
