hanguofu Posted October 21, 2018 Posted October 21, 2018 I installed Armbian_5.60_Aml-s9xxx_Ubuntu_xenial_default_4.18.7 to the EMMC of my s905x TV Box , so far so good . Yesterday I trimmed some drivers and built the kernel successfully . The following packages are generated with armbian build tool : linux-dtb-aml-s9xxx_5.60_arm64.deb linux-headers-aml-s9xxx_5.60_arm64.deb linux-libc-dev-aml-s9xxx_5.60_arm64.deb linux-image-aml-s9xxx_5.60_arm64.deb linux-source-default-aml-s9xxx_5.60_all.deb I am going to ssh into my box and run "dpkg -i " commands to update kernel . Is it safe to do so while Armbian is running ?
jock Posted October 21, 2018 Posted October 21, 2018 Yes, of course. the kernel completely resides in memory once the system is booted, so you can update it safely.
balbes150 Posted October 21, 2018 Posted October 21, 2018 3 hours ago, hanguofu said: I am going to ssh into my box and run "dpkg -i " commands to update kernel . Is it safe to do so while Armbian is running ? For security reasons, before updating, save all the contents of the /boot partition and modules (for example, in the "root" user directory), so that in case of problems, it is easy to return to the current state.
jock Posted October 21, 2018 Posted October 21, 2018 I agree, doing a backup of the boot partition is highly advisable before doing kernel update (even apt-get upgrade), expecially if you are running a non-official armbian. Normally the upgrade scripts do a copy of the old kernel/initrd themselves, but very often I lost some files in the process. It is quite time consuming and annoying try to restore the old kernel from working images
