AZ8 Posted October 22, 2018 Posted October 22, 2018 Yesterday I have installed Armbian to my 3-years-old banana-m1 (previosly ran on bananian 16.04 with 4.4.66 kernel) Tiday I have installed rtorrent and tried to download 44 gb file using rtorrent (with lot of seeders). Few minutes, and I got massive bunch of errors [11583.126199] blk_partition_remap: fail for partition 2 [11583.126314] blk_partition_remap: fail for partition 2 ... [11583.136689] blk_partition_remap: fail for partition 2 and USB drive reconnected in ro mode. Then I remount drive, started torrent again and exactly same issue, USB drive disconnected. USB drive connected with external power.
Igor Posted October 23, 2018 Posted October 23, 2018 19 hours ago, AZ8 said: Yesterday I have installed Armbian This is my system: http://ix.io/1pQZ (yours is unknown). I was stressing my Banana M1 (this one) + USB Hub + 128GB SSD for some time and there is not a single glitch in the log. Currently downloading torrents: debian-9.5 DVD1,2,3 and a few Ubuntus at around 10MB/s + stressing more on the way, creating large files, ... Diff: I used self build image and transmission, which is one click install from armbian-config. I seriously doubt there is a problem in kernel and that was fixed in last few weeks (switching to nightly will give you the same version and you can try that). Can't reproduce, nothing wrong with Armbian.
AZ8 Posted October 23, 2018 Author Posted October 23, 2018 3 hours ago, Igor said: This is my system: http://ix.io/1pQZ (yours is unknown). I was stressing my Banana M1 (this one) + USB Hub + 128GB SSD for some time and there is not a single glitch in the log. Currently downloading torrents: debian-9.5 DVD1,2,3 and a few Ubuntus at around 10MB/s + stressing more on the way, creating large files, ... Diff: I used self build image and transmission, which is one click install from armbian-config. I seriously doubt there is a problem in kernel and that was fixed in last few weeks (switching to nightly will give you the same version and you can try that). Can't reproduce, nothing wrong with Armbian. Yes, with Transmission downloading started and finished without any issues, but - limited to about 10 MB/s While rTorrent downloading in about 18-20 MB/s. Right now I have set download speed limit for rtorrent to prevent disconnects.
Igor Posted October 23, 2018 Posted October 23, 2018 21 minutes ago, AZ8 said: but - limited to about 10 MB/s I haven't seen more than 15MB/s on any other machine as well. It should go up to 30MB/s but my router can't. Since I don't really care about the download speed ... I did various stress test as well. You can further experiment with other kernels if that makes any diff. Use latest https://github.com/armbian/config - I added this today, that you can try going back with the kernel (to 4.11.y) and quickly see if changing kernel has any effect on this. You can also try DEV kernel (4.18.y).
AZ8 Posted October 24, 2018 Author Posted October 24, 2018 17 hours ago, Igor said: I haven't seen more than 15MB/s on any other machine as well. It should go up to 30MB/s but my router can't. Since I don't really care about the download speed ... I did various stress test as well. You can further experiment with other kernels if that makes any diff. Use latest https://github.com/armbian/config - I added this today, that you can try going back with the kernel (to 4.11.y) and quickly see if changing kernel has any effect on this. You can also try DEV kernel (4.18.y). Looks like USB drive is broken. Today at night banana reboted and starts to reboot again and again seconds after boot till I disconnected usb drive physically. Log https://pastebin.com/GmHP8tgC 1
