Leitnin Posted October 23, 2018 Posted October 23, 2018 Hey there. I used to run an Octoprint server on my Orange Pi Zero H2+ installed over armbian, which got swapped with a raspberry pi for unimportant reasons. I wanted to switch back, but for all of the armbian builds listed here for Orange Pi Zero, I am just getting a green light on the board and some blinking of the orange indicator only from the Ethernet Jack. Is this expected? This is happening with multiple SD-cards an two Orange Pi Zeros. All of the OS images from http://www.orangepi.org/ seem to work just fine, as well as an old "debian_server_for_orangepizero_v0_9_2.img" I found, so I'm going that route for now. But I can't image this is expected behavior.
Igor Posted October 23, 2018 Posted October 23, 2018 Images were tested by us and by many people every day. Those images are most used. It must be something on your side:https://docs.armbian.com/User-Guide_Getting-Started/https://forum.armbian.com/forum/31-sd-card-and-power-supply/ perhaps this: Without serial console logs ... there is nothing we can do.
Leitnin Posted October 23, 2018 Author Posted October 23, 2018 Thank you for the link. I imagined there would be little to be done without more information. Curiously, after going through setup on another debian build, I decided to give the stretch img another shot, and now it seems to be working. The only thing different is, it is being powered by a USB cable not from a simple power supply, but from a PC (and recognized as PI USB to serial )No idea if that is relevant, but it seems to be working now. 1
