From a fresh new install (after upgrade), I try to install OpenMediaVault + OwnCloud using armbian-config, it leads to apt's lock out.:
I have proceed, another time, and it leads to the same result.
The troublesome package seems to be "openmediavault-omvextrasorg":
"Removing openmediavault-omvextrasorg (4.1.11) ...
/var/lib/dpkg/info/openmediavault-omvextrasorg.postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions
dpkg: error processing package openmediavault-omvextrasorg (--remove):
 subprocess installed post-removal script returned error exit status 2
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)"
Any workaround ?
Thanks
OMV installation works.
'+ owncload is almost certainly not possible without sever hacking.
Thanks for your answer Igor.
Sorry I would say NextCloud instead of OwnCloud (I came from OwnCloud and have not completed the naming switch in my brain)
Should I install OMV from armbian-config and then NextCloud manualy ?
both are some sort of NAS (network attached storage) - while I guess NC offers you more option. So the question is:
Why do you need both ?
No, you have to pick one of. Both suits the same purpose as @Tido pointed out and use the same low level services.
I definitely don't need both, I just try to install NC from armbian-config and it broke OpenMediaVault (see error message in my first post)
OMV works, NC cloud as well. Both can't work unless you use some kind of virtualization. Problem is unrelated to Armbian.
Case closed.
  • Igor locked this topic
  • Igor unlocked this topic
