Mr Blue Posted March 19, 2016 Posted March 19, 2016 Hi! I plan to use a Banana Pi as a file server and install the system on the hard drive. The documentation page says: SATA/USB: pre-partitioned SATA or USB storage How does the nand-sata-install script work? Will I need to pre-partition my hard drive or will the script do it? Will it just partition it as one big ext4? Is it possible to make at least two partitions, one for the system and one for the files?
Igor Posted March 19, 2016 Posted March 19, 2016 You will be prompted to select to which partition you want to install. Just prepare one that will be used for system, the rest is unlimited.
