trebor Posted November 1, 2018 Posted November 1, 2018 Hello, After installing Armbian 5.59 I have problems with sound. When I install the distribution with the 4.14.69 kernel, I have an intermittent sound. When with 4.18.7 sound is missing. How can I fix it? Is it possible to change the kernel? If so, please follow the instructions step by step. greetings trebor
TonyMac32 Posted November 1, 2018 Posted November 1, 2018 Hmmm, I'm catching up on what was more or less an extended absence, I'll have to add this to the list. It will be a kernel driver issue if it's anything.
trebor Posted November 2, 2018 Author Posted November 2, 2018 Thank you for your answer. Probably it will take a while. Is it possible to replace the kernel with older ones? How to do it?
trebor Posted November 12, 2018 Author Posted November 12, 2018 Is there any new information about sound drivers?
TonyMac32 Posted November 13, 2018 Posted November 13, 2018 The sound on these boards is thanks to a set of patches by @JeromeB as part of the work on the Amlogic SoC's. I have not spent enough time with 4.18/4.19 to know what is going on there exactly, I have, however, updated patches recently to match the current recipes by BayLibre, I think sound may be available now (as of 4.18.16). I don't know if any build has taken place since then, but the kernel has other issues, so it may not be wise to change yet.
trebor Posted November 13, 2018 Author Posted November 13, 2018 Thank you for the information. I will check and test the sound.
trebor Posted November 14, 2018 Author Posted November 14, 2018 The kernel 4.18.18-meson64 sound has returned. Thank you for your hard work.
