Guest Posted November 4, 2018 Posted November 4, 2018 Hello! I've recently installed NextCloudPi, which ships Linux 4.4 by default (linux-image-rockchip64 - Linux kernel, version 4.4.159-rockchip64). Is it OK to update to linux-image-arm64? As far as I understood, mainline Linux supports RK3328 chip since version 4.14. Thanks a lot!
Igor Posted November 5, 2018 Posted November 5, 2018 19 hours ago, Gengan said: Is it OK to update to linux-image-arm64? Probably it will not work out of the box (apt install ...) and will definitely be a step back ATM. We provide modern 4.19.y kernel for RK3328/3399 (linux-image-dev-rockchip64) for developers & testing. It is present only in a nightly repository ATM. It comes with no warranty or support. Generic ARM kernel is months behind this at best.
Guest Posted November 5, 2018 Posted November 5, 2018 OK, thanks for your reply Can I also ask you if you plan to mark kernel 4.19 as the next stable version of linux-image-rockchip64? I'm not asking for an ETA.
