Владимир Юдин Posted November 11, 2018 Posted November 11, 2018 Hello. I try to put on Zero Armbian Jessie, after rebooting it does not connect via SSH. Tell me where I make a mistake. Thank.
Владимир Юдин Posted November 11, 2018 Author Posted November 11, 2018 (edited) OPi Zero H2 armbianmonitor -u запускается перед перезагрузкой? иначе я не смогу подключиться через SSH http://ix.io/1rxE Edited November 11, 2018 by Владимир Юдин
guidol Posted November 11, 2018 Posted November 11, 2018 4 hours ago, Владимир Юдин said: Hello. I try to put on Zero Armbian Jessie, after rebooting it does not connect via SSH. Tell me where I make a mistake. Thank. Did you try to SSH to the IP xx.xx.0.105 in your network? default via XXX.XXX.0.1 dev eth0 inet XXX.XXX.0.105/24 eth0 Do you got a DHCP-Server (I think because of the .105)
Владимир Юдин Posted November 11, 2018 Author Posted November 11, 2018 2 hours ago, guidol said: Вы пытались выполнить SSH на IP xx.xx.0.105 в своей сети? Yes, it is in your router, connected via LAN 2 hours ago, guidol said: У вас есть DHCP-сервер No
