fux Posted November 11, 2018 Posted November 11, 2018 Dear all I have the problem that when I reboot my banana pi pro it always creates a new eth0 config. Which as default has ip4 disabled hence I cant see it directly. At the moment I always access the pi via ip6 and than delete the config via nmtui. My question: How can I turn the creation of a new eth0 config on reboot off? ARMBIAN 5.60 stable Ubuntu 18.04.1 LTS 4.14.70-sunxi Thanks
Igor Posted November 11, 2018 Posted November 11, 2018 Are you using only Network manager? /etc/network/interfaces is empty? and /etc/netplan and /etc/networkmanager/system-connections contains what?
sfx2000 Posted November 12, 2018 Posted November 12, 2018 Check the MAC address of eth0 - is it steady? One of the common issues with the DesignWare MAC/GMAC on AllWinner and other SoC's that use the same IP block, is that they have a random MAC address - with IPv6, this obviously will have some challenges. Check the ethaddr in uboot - you can set a value there... it's supposed to be a fixed address after first boot, but many of the DWMAC/GMAC implementations let it float...
fux Posted November 13, 2018 Author Posted November 13, 2018 Thanks for your replies guy: @Igor fux@bananapipro:~$ cat /etc/network/interfaces source /etc/network/interfaces.d/* # Network is managed by Network manager auto lo iface lo inet loopback dns-nameservers 192.168.1.1 8.8.8.8 fux@bananapipro:~$ cat /etc/netplan cat: /etc/netplan: No such file or directory fux@bananapipro:~$ /etc/networkmanager/system-connections -bash: /etc/networkmanager/system-connections: No such file or directory fux@bananapipro:~$ cat /etc/networkmanager/system-connections cat: /etc/networkmanager/system-connections: No such file or directory I just used nmtui as far I am aware. @sfx2000 No seems to be stable. Neither deleting the newly created eth0 configs nor the reboot changes the mac address. Oh and what is interesting is that it always greats the same new ip6 addres. Thanks
Igor Posted November 14, 2018 Posted November 14, 2018 5 hours ago, fux said: seems to be stable. If MAC is not changing, than the problem is most likely outside of Armbian domain. Do some general investigation. ls -l /etc/netplan/* -> 01-netcfg.yaml One of my machines: Spoiler # This file describes the network interfaces available on your system # For more information, see netplan(5). network: ethernets: ens3: addresses: [172.16.100.38/24] gateway4: 172.16.100.1 optional: true nameservers: addresses: [8.8.8.8,8.8.4.4] version: 2 ls -l /etc/NetworkManager/system-connections is empty
