I have OrangePi PC and I'd like to use HC-12  serial communications device.
I've successfully used it with RaspberryPi Zero with these instructions: http://dev.drun.net/2017/05/10/reading-hc-12-from-rpi-and-sending-to-domoticz/
I've found this useful info: https://forum.armbian.com/topic/1524-orange-pi-one-how-to-enable-uart/
I've connected the HC-12 to OPPC as follows:
VIN – Connect to  3.3 (PIN 2)
GND – Connect to  GND (PIN 6)
RX – Connect to (PIN 8, UART0_TXD)
TX – Connect to (PIN 10, UART0_RXD)
I've got Putty connected to OrangePi.
command "ls /dev/tty*" shows that I have /dev/ttyS0. I've tried to use it with Minicom: sudo minicom -b 9600 -o -D /dev/ttyS0
..to no avail. "uname -a" command shows "Linux orangepipc 3.4.113-sun8i #68 SMP PREEMPT Wed Sep 19 10:23:30 CEST 2018 armv7l armv7l armv7l GNU/Linux"
I opened the script.fex and it shows:
[uart0]
uart_used = 1
uart_port = 0
uart_type = 2
uart_tx = port:PA04<2><1><default><default>
uart_rx = port:PA05<2><1><default><default>
[uart1]
uart_used = 0
uart_port = 1
uart_type = 4
uart_tx = port:PG06<2><1><default><default>
...etc. I have no clue what these mean. The first useful info above mentions that I should modify them.
What should I try next?
If you look at OPiPC schematic, the Pin 8/10 are not UART0 but UART3, UART0 is connected on 3 pins Serial Debug header and used by kernel to output debug logs, so usable for your HC-12.
so in your script.fex, it should be present and "uart_used" should be 1 not 0 to activate it at next reboot.
UART3 should then be accessible as /dev/ttyS3 ...
Thank you for your reply.
Just to clarify. I'd rather not change script.bin in fear I mess something.
If I connect the RX and TX wires from the HC-12 to the 1+2 (GND, RX,TX) pins next to the HDMI connection (should ground be connected as well?) can I leave script.bin as it is?
Will it affect Putty?
If If have to change:
[uart1]
uart_used = 0
[uart1]
uart_used = 1
will I then have "/dev/ttyS1" available. Where shoul the HC-12 RX/TX wires then go?
But your HC-12 will receive a lot of junk since the kernel will output log there, especially at boot time. But you can try ... (be aware that this one is /dev/ttyS0)
[uart1]
uart_used = 1
UART1 on OPiPC is pin38/40, but simply edit script.fex doesn't do anything until you recompile it as script.bin (make sure to backup original)
OK gathered enough courage to edit script.fex and compile it to script.bin and then reboot:
[uart3]
uart_used = 1
uart_port = 3
uart_type = 4
uart_tx = port:PA13<3><1><default><default>
uart_rx = port:PA14<3><1><default><default>
I have HC-12 RX wire going to Orangepipc pin 8 (PA13 TX)
and
HC-12 TX wire going to Orangepipc pin 10 (PA14 RX)
Now sending using /dev/ttyS3 appears to work, but receiving not. What could be the problem?
Other Orange Pi PC features seem towork fine (Putty, net etc)
I don't have much ideas : are you sure you didn't mix TX and RX ? If you pull down the "SET" pin, do you have answers when sending an AT command ?
