Hi on my Banana PI I have set no swapfile/partition since I never gonna use swapspace ram is gonna be enough. When I reboot I always find 499MB of swap
 swapon -s
Filename                                Type            Size    Used    Priority
/dev/zram1                              partition       255728  67052   5
/dev/zram2                              partition       255728  66836   5
But I can find no entry of /dev/zram1 nor /dev/zram2 in /etc/fstab. Can anybody explain me how is this possibile? And how to manage those partitions?
I found another /dev/zram0 which I think has to deal with log2ram since it is mounted on /var/log, is this correct?
Thanks
4 hours ago, pazzoide said:
So where does it come from???
armbian-zram-config.service, which is closely linked to armbian-ramlog.service
Doesn't hurt to keep them enabled, but if one wants, you can disable them using systemctl disable <name of service>
There's benefit to keeping them on - reduces writes to the flash device.
8 hours ago, pazzoide said:
what I don't understand is
two (2) posts above yours there is a link. Did you read that thread ?
Thank you so much!
It's worked.
at the end of 【/usr/lib/armbian/armbian-zram-config】
add #
like this:
case $1 in
123     *start*)
124     #   activate_zram_swap
125         activate_ramlog_partition
126         activate_compressed_tmp
127         ;;
128 esac
it close zram_swap.
