tkaiser 1646 Posted November 2, 2017 Share Posted November 2, 2017 I added a while back 'free' output to 'armbianmonitor' and 'armhwinfo' to get some monitoring data from real-world installations about swap usage. Armbian uses an emergency swap file of 128MB by default (vm.swappiness=0) which means swapping should be avoided unless really needed. Let's have a look and extract data from +50 support URLs collected within the last months. I piped the output of https://pastebin.com/raw/DjxAX6Rn through while read ; do curl -q "${REPLY}" | grep '^Swap: '; done | sort | uniq -c and this is what we end with: 175 Swap: 127M 0B 127M 1 Swap: 127M 22M 105M 1 Swap: 127M 256K 127M 3 Swap: 2.0G 0B 2.0G 1 Swap: 513M 0B 513M 1 Swap: 617M 0B 617M So we have 182 times swap usage monitored and get 1 single occasion when swapping occured (the 256KB case here was not swapping but zram instead and the 22MB case there is the only occurence of real swapping and also an 'Out of memory: Kill process' event has been logged with kernel 4.11, no idea what @op1tjaap did back then). IMO this justifies overthinking our approach especially on boards with low memory since zram is an alternative. Currently there are a few hundred Armbian installations out there running Jessie with Ubuntu's zram-config package installed (zero swap configured, vm.swappiness=0, zram-config defaults resulting in zram area half the size of physical available memory). Not a single complaint so far. But vm.swappiness=0 is a pretty bad setting for such a configuration since as we see above swapping will be avoided anyway if possible. When using vm.swappiness=100 available DRAM will be used way more efficient. But I've to admit that in my testings available memory has never been an issue anyway. So what about the following: add zram-config to Xenial default package list modify /etc/init.d/firstrun to skip swap file creation if this package is installed and branch=next|dev and set vm.swappiness=100 instead of vm.swappiness=0 This way we can collect within half a year some details about zram usage (count of complaints and again collecting free output through 'armbianmonitor -u' output) Edit: Added mainline kernel requirement Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 2, 2017 Share Posted November 2, 2017 36 minutes ago, tkaiser said: modify /etc/init.d/firstrun to skip swap file creation if this package is installed and set vm.swappiness=100 instead of vm.swappiness=0 We can leave this as is but check swap priorities. I remember reading about zram having higher priority than default file/partition based swap, but it needs confirming. Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 2, 2017 Author Share Posted November 2, 2017 12 minutes ago, zador.blood.stained said: We can leave this as is but check swap priorities. If we leave it 'as is' then we can stop here since vm.swappiness=0 results in neither zram nor swap used unless really needed (and then there are no positive effects and we can leave everything as is). No idea how vm.swappiness was set for the 'Swap: 127M 256K 127M' entry above -- maybe @dragonlost can comment on this? At least this here was me having activated zram with vm.swappiness defaults (AFAIK that's 60). As can be seen there's slight zram usage with zero swap but I can't remember exactly what I did back then (since 4 SATA devices are attached most probably ZFS/RAID tests). But with a default vm.swappiness value we might end up with swap on SD card being really used even in situations where 'cold pages' sit compressed in zram and the host is swapping to death with hot pages on SD card. This is nothing I would roll out as part of a new Armbian release. So IMO the only reasonable test scenario is dropping swap entirely, using only zram and vm.swappiness=100 To sum it up: vm.swappiness=0 --> no need to test since behaviour not different than today. Hosts limited to real physical memory, only emergency behaviour when really running out of memory would change vm.swappiness default (60?) --> very interesting to test with swap and zram but I fear negative behaviour once paging reaches SD card (see also 'RAM + ZRAM + SWAP (on HDD)' section here) vm.swappiness=100 --> only useful without swap configured. As we can see above at least the 53 'participating' parties ran really out of memory only once ( @op1tjaap might remember what happened back then) I'm not interested in exploring better 'emergency situation' behaviour but in enabling SBC with low memory to make better use of available DRAM. I mean: that's what zram has been invented for on Android devices: Cope with low memory situations and avoid swapping to slow flash. And it works in the meantime on hundreds of millions of devices (and a few hundred -- counting Raspberries too then even a few thousand -- Armbian installations running OMV) Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 2, 2017 Author Share Posted November 2, 2017 Another quick check: grepping for 'Out of memory' in all debug logs: [ 1374.514623] Out of memory: Kill process 5386 (supertuxkart) score 523 or sacrifice child (also an occurence of real swap usage I missed before since whole system configured to use french: 'Partition d'échange') [ 3790.835574] Out of memory: Kill process 2143 (python2.7) score 624 or sacrifice child (that's the other swapping occurence) I checked again (this time searching for ' 127M ') and we had 2 real swap scenarios in 182 cases and in both oom-killer 'resolved' the issue anyway. Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 2, 2017 Share Posted November 2, 2017 (edited) Just a quick check on a laptop (Ubuntu 17.10 x86_64, zram-config is installed) that I'm writing this post from ➜ ~ % swapon --show NAME TYPE SIZE USED PRIO /dev/dm-0 partition 953,5M 0B -1 /dev/zram0 partition 751,2M 181,5M 5 /dev/zram1 partition 751,2M 182,5M 5 ➜ ~ % sysctl vm.swappiness vm.swappiness = 60 ➜ ~ % LANG=en free -h total used free shared buff/cache available Mem: 2.9G 2.1G 305M 249M 579M 555M Swap: 2.4G 383M 2.0G ➜ ~ % IMO we may not need setting vm.swappiness to 100, as you can see zram will be preferred over disk/file based swap. "Once paging reaches SD card" means that zram is (almost) full and user chose a device with less RAM that is viable for the use case, at this point without zram the system would be out of memory already. Though we need to test how different vm.swappiness values (i.e. 0, 60 and 100) interact with multiple swap devices, at which point swapping goes to a lower priority device - only when higher priority devices are 100% full or earlier? Edited November 2, 2017 by zador.blood.stained Replaced swapon -s (listed as deprecated in man) with swapon --show; added free -m Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 2, 2017 Author Share Posted November 2, 2017 1 hour ago, zador.blood.stained said: Though we need to test how different vm.swappiness values (i.e. 0, 60 and 100) interact with multiple swap devices, at which point swapping goes to a lower priority device - only when higher priority devices are 100% full or earlier? Well, that might depend on a lot of other vm related stuff, most importantly few of the last ones on below list (that's a sysctl dump from XU4 4.9 kernel): vm.admin_reserve_kbytes = 8192 vm.block_dump = 0 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirty_writeback_centisecs = 500 vm.dirtytime_expire_seconds = 43200 vm.drop_caches = 0 vm.extfrag_threshold = 500 vm.highmem_is_dirtyable = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 32 32 vm.max_map_count = 65530 vm.min_free_kbytes = 3454 vm.mmap_min_addr = 4096 vm.mmap_rnd_bits = 8 vm.nr_pdflush_threads = 0 vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 3 vm.panic_on_oom = 0 vm.percpu_pagelist_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 63391 vm.vfs_cache_pressure = 100 vm.watermark_scale_factor = 10 I think we all agree that swap hitting the SD card can be considered 'game over' especially when happening on 'average' SD cards (thosethe majority of users bought with 2-10 random write IOPS at 16K block size). Our strategy to deal with this in the past was to set vm.swappiness to 0 as a try to prevent swapping in any situation. When we now still allow swap on SD card and increase swappiness then depending on kernel and other defaults we (or our users) might end up with situations where once the kernel is running out of zram swap devices it starts to swap to SD card (game over). As far as I understood this is not something comparable to 'tiered storage' where each storage layer is handled appropriately (and 'hot data' gets moved on demand) but this is just a couple of different swap devices with different priorities that are used based on a rather simple strategy. So if swap on SD card is allowd the system might use it for 'hot data' once the zram swap devices are full (containing partially 'cold data' then). If we want to avoid 'swap on SD card' and also avoid testing through all different kernels and distros (that might tweak this or that somewhere -- see Ubuntu's ondemand service that interfered with our cpufreq settings) then IMO the easy way is to drop 'swap on SD card' entirely. We can assume this works pretty well with vm.swappiness=0 (since that's tested by OMV users in the meantime) so let's try to get some experiences with higher swappiness values. Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 2, 2017 Share Posted November 2, 2017 2 minutes ago, tkaiser said: I think we all agree that swap hitting the SD card can be considered 'game over' especially when happening on 'average' SD cards (thosethe majority of users bought with 2-10 random write IOPS at 16K block size). Our strategy to deal with this in the past was to set vm.swappiness to 0 as a try to prevent swapping in any situation. Still vm.swappiness=0 is not "preventing swapping in any situation", though the behavior was changed in kernel 3.5 (so we have slightly different logic between legacy 3.4 and all other kernels): https://github.com/torvalds/linux/commit/fe35004fbf9eaf67482b074a2e032abb9c89b1dd This definitely doesn't say "prevents swapping in any situation" swappiness This control is used to define how aggressive the kernel will swap memory pages. Higher values will increase agressiveness, lower values decrease the amount of swap. A value of 0 instructs the kernel not to initiate swap until the amount of free and file-backed pages is less than the high water mark in a zone. The default value is 60. 14 minutes ago, tkaiser said: If we want to avoid 'swap on SD card' and also avoid testing through all different kernels and distros (that might tweak this or that somewhere -- see Ubuntu's ondemand service that interfered with our cpufreq settings) then IMO the easy way is to drop 'swap on SD card' entirely. We can assume this works pretty well with vm.swappiness=0 (since that's tested by OMV users in the meantime) so let's try to get some experiences with higher swappiness values. I agree with dropping swap on SD for new images and using zram where it's possible. I'm just against adding any new swap related logic (except logging) to firstrun and armhwinfo - those 2 services have enough tweaks not related to each other and enough legacy and partially unmaintained code. vm.swappiness value can be tweaked by installing a file to /etc/sysctl.d/ in board support packages, though IMO for Ubuntu with zram only default value of 60 is good enough. Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 2, 2017 Author Share Posted November 2, 2017 47 minutes ago, zador.blood.stained said: Still vm.swappiness=0 is not "preventing swapping in any situation" Yeah, so let's get rid of this rather sooner than later. My personal timeline for the approach (expectations vs reality included ): Started to prepare this 7 months ago: https://github.com/armbian/build/commit/de059a12a9f8ab7f3b40ab8e2e3671030e5dd51e#diff-01333a069633e14fb9510b0dbedadab5 Naively thought 2 months later we would've collected enough reports to get a clue what's going on (I wanted to wait for 50 different logs) so that we can drop 'swap on SD card' with next release Well, (not so) surprisingly I had to wait until now (7 months) to get those ~50 debug logs containing ~180 swap usage reports (and 2 times swapping really happened) Since 2-3 months few hundred to thousand OMV users test 'no swap on SD card' successfully already but with settings that don't make better use of the physical memory Now we know a little bit wrt 'out of memory' situations (I wouldn't call those ~50 debug logs representative but at least it's more than nothing) and that it seems to work pretty well to avoid swap on SD cards. 53 minutes ago, zador.blood.stained said: I'm just against adding any new swap related logic (except logging) to firstrun and armhwinfo But then any further testing is useless since how to get rid of the swap file then? The reason why I want to (temporarely) implement this as proposed is that in Ubuntu Xenial it's as easy as adding 'zram-config' to a variable in our build system to get zram activated automagically. So all that's missing is not enabing the swap file and then collect real-world experiences from our users so that we can then (maybe in half a year) decide whether to use Ubuntu's zram-config package everywhere (works flawlessly with both Jessie and Stretch BTW) or we implement this as an own startup service. I absolutely second the idea to move the vm.swappiness setting to a BSP contained file below /etc/sysctl.d/ but this does not solve the real problem to collect experiences now. At least in my testings (server and NAS use cases) I can not force excessive vm usage anyway. Seems the daemons I deal with are all well-behaving so we need some real-world experiences from people using SBCs as desktop and stuff like this. So I still propose a simple firstrun logic change making creation of the swapfile optional based on existence of zram-config package. Once we collected new experiences this can be dropped altogether or reverted back to mandatory swapfile creation. Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 2, 2017 Share Posted November 2, 2017 5 minutes ago, tkaiser said: But then any further testing is useless since how to get rid of the swap file then? Collect stats from new images for now (where we are sure that we have recent enough kernel, userspace and board support package versions), maybe add a manual switch (option) to armbian-config. We can always (try to) push new settings to older images later, though I'm not a fan of silently making changes that will conflict with existing forum posts and documentation. (I though that you want to push some logic to armhwinfo to disable/delete AD swap file on existing images.) 11 minutes ago, tkaiser said: So I still propose a simple firstrun logic change making creation of the swapfile optional based on existence of zram-config package. OK, I'm not against that (making the swap file logic and setting swappiness to 0 optional) Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 2, 2017 Share Posted November 2, 2017 To simplify rootfs build time caching we could add zram-config to all new images but control its startup by a systemd override file. Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 2, 2017 Author Share Posted November 2, 2017 18 minutes ago, zador.blood.stained said: I though that you want to push some logic to armhwinfo to disable/delete AD swap file on existing images. Nah, only new images and clearly mentioning in release/changelog: 'Ubuntu Xenial images use zram instead of swap' (so anyone concerned about stuff not working as 20 years ago any more can choose Stretch for now). No modification of already existing images, the goal is to provide new images with a documented change. 17 minutes ago, zador.blood.stained said: To simplify rootfs build time caching we could add zram-config to all new images but control its startup by a systemd override file. Well, I wanted to activate the new behaviour on all boards by default with Xenial since it's pretty interesting to get feedback from Orange/NanoPi with just 256 MB as well as devices with 2 or even 4 GB. If vm.swappiness is controlled by a eg. /etc/sysctl.d/armbian-vm-tweaks from now on we can react quickly if we discover problems where vm.swappiness=60 doesn't fit (and since it's known that vm.swappiness=0 works even worst case scenarios can be fixed with an 'apt upgrade' on user's side) Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 2, 2017 Share Posted November 2, 2017 1 hour ago, tkaiser said: If vm.swappiness is controlled by a eg. /etc/sysctl.d/armbian-vm-tweaks from now on we can react quickly if we discover problems where vm.swappiness=60 doesn't fit (and since it's known that vm.swappiness=0 works even worst case scenarios can be fixed with an 'apt upgrade' on user's side) Adding sysctl files to the board support package will change this setting also for all previous images, so I thought about relying on kernel default value of 60. Looks like Ubuntu doesn't provide any tweaks for vm.* sysctl parameters except security related vm.mmap_min_addr. Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 4, 2017 Author Share Posted November 4, 2017 On 2.11.2017 at 6:04 PM, zador.blood.stained said: To simplify rootfs build time caching we could add zram-config to all new images With latest commits it's now implemented like this: zram-config added to Xenial default package list firstrun checks for this package and if installed will neither create a swap file nor write vm.swappiness=0 to /etc/sysctl.conf nand-sata-install (hopefully) learned to deal with what's configured and will honor existing settings when transferring installation So only new Xenial images are affected currently since there SD card based swap will be replaced by zram with default vm.swappiness. I did a lot of testing mostly with legacy kernels and to be honest find it really hard to 'measure' effects. With Pinebook I had to open 40 Chromium tabs to let Chromium eat up to 2.7 GB memory and as expected it just felt slow. But it feels slow all the time (compared to what I'm used to) so it's really hard to 'measure' any effects. I read about people adjusting vm.swappiness to much lower values happily reporting back that 'everything way better now' but based on user experience tests I wouldn't count on this and my personal tests resulted in me just thinking 'well, still slow'. With my very own use cases (server tasks) I'm not able to get zram swap being used extensively, mostly since it seems I'm only using daemons that behave well. So we really need some experiences made by users out there. In the meantime installation of zram-config package is not needed any more since I added everything this package does to an activate_zram function in armhwinfo (wrong place, I know -- reasons below). I took most of the functionality unaltered except a few details amount of memory used is the same (half of DRAM) and it's only configurable by adjusting armhwinfo code (done by intention, I really want to avoid dealing with problem reports from users adjusting everything to death while not even understanding virtual memory and paging basics) number of zram devices == count of CPU cores but limited to 4 (using all CPU cores works well on x86 but we don't want compression/decompression happening on A7 cores in big.LITTLE designs) set LZ4 as algorithm where possible (otherwise fallback to what the kernel is configured to use -- LZO today -- will happen). This might need adjustments in the future if we switch to 'better' compression algos on a specific platform (eg. zstd -- an interesting read here) So what's next (please keep in mind that I'm solely focused on a way to collect user experiences in the least 'expensive' (time consuming) way -- it kinda sucks how much efforts are needed to get good user feedback! With new Xenial images users are testing zram + vm.swappiness=60 behaviour Experienced users who know what they do can be encouraged by another forum thread to start experimenting with zram on their installations (it's as easy as uncommenting the 'activate_zram' line in armhwinfo, adjusting vm.swappiness in /etc/sysctl.conf and/or deleting the swap entry in /etc/fstab) Experienced users with interesting hardware setups (eg. running off pretty fast ODROID eMMC or a SATA SSD and not a slow SD card) can be encouraged to do even more testing (combining zram with swap on SSD for example with modified vm.swappiness) We can uncomment the 'activate_zram' line in armhwinfo in a few months causing no harm on existing installations since due to vm.swappiness=0 there nothing will change (only emergency swap behaviour will improve a lot) In half a year based on the collected experiences we can remove zram-config from Xenial package list and finally adjust firstrun to skip swapfile creation and adjusting vm.swappiness (or maybe we came up with a better value in the meantime and set this as default) There's only a single change that affects already existing installations and that would be activate_zram enabled which only affects (improves) emergency swap behaviour. All other changes only affect new images/installations so users are safe. BTW: What about renaming armhwinfo? For example armbian_hw_setup? Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 4, 2017 Share Posted November 4, 2017 20 minutes ago, tkaiser said: BTW: What about renaming armhwinfo? For example armbian_hw_setup? I would prefer to split it into multiple services: a logging service, an optimizing service, a hardware monitoring service, etc. And instead of reinventing the wheel with zram we could use a systemd-swap service, i.e. this implementation from Arch Linux: https://github.com/Nefelim4ag/systemd-swap This way it would be easy to disable individual components of Armbian that may not be needed or that may interfere with other services (i.e. your "activate_zram" function checks only for zram-config package and it would interfere with systemd-swap installed by users without an easy way to disable it (since any changes to armhwinfo will be lost on upgrade)) 1 Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 4, 2017 Author Share Posted November 4, 2017 1 hour ago, zador.blood.stained said: And instead of reinventing the wheel with zram we could use a systemd-swap service, i.e. this implementation from Arch Linux: https://github.com/Nefelim4ag/systemd-swap Well, giving up on the approach now. It took 7 months to get at least some sparse information wrt swap usage on real-world Armbian installations and I clearly don't want to wait another few months to see any improvements. Relying on systemd-swap or any other already existing 'solution' will not work that great 'on Armbian' since all those attempts are made only for x86 situation (requiring recent kernels, no big.LITTLE problem, zswap better than zram and so on). Emergency swap is fine... Edit: systemd-swap's zram activation routine (which while being the only part of interest on SBC is disabled by default) needs to be rewritten entirely anyway to work properly or at all on Armbian. Link to post Share on other sites More sharing options...
op1tjaap 5 Posted November 11, 2017 Share Posted November 11, 2017 Sorry. No idea what I was doing. I know this doesn’t sound very intelligent. Will check if my “MacIPpi thing” caused more swapping. Link to post Share on other sites More sharing options...
Tido 187 Posted November 12, 2017 Share Posted November 12, 2017 On 4.11.2017 at 11:57 AM, zador.blood.stained said: I would prefer to split it into multiple services: a logging service, an optimizing service, a hardware monitoring service, etc. Sound like a good Unix approach. @tkaiser, I remember that you once explained to Wildcat_Paris that if his system is using SWAP - there is something wrong. Whereas it doesn't hurt to have that little partition - it also supports to analyze if your SBC goes crazy, right? If you look at it from your side - I might have stumbled across it, but what is the major benefit of leaving away this SWAP partition? Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 12, 2017 Author Share Posted November 12, 2017 26 minutes ago, Tido said: Sound like a good Unix approach. So when do you start to implement this? You won't just like no one else will anytime soon or ever and if this is the requirement to switch from swap to zram (as it seems) then it's as I already said: On 4.11.2017 at 1:08 PM, tkaiser said: Emergency swap is fine... Since it seems I'm the only one interested in improving DRAM usage on small boards and wasted already way too much time on this approach I've just given up. And if you have to ask the question you asked I can only recommend to read the thread you posted to since it's explained in detail. Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted November 12, 2017 Share Posted November 12, 2017 12 minutes ago, tkaiser said: You won't just like no one else will anytime soon or ever and if this is the requirement to switch from swap to zram (as it seems) It's a requirement to have a maintainable code and not a 500+ lines of code in a single service. Especially outdated code, since starting with kernel 4.2 it's possible to reconfigure zram on the fly without unloading the module and new distributions (unfortunately not Jessie but Xenial, Stretch and newer) provide a "zramctl" utility that can configure zram devices and display useful statistics. Link to post Share on other sites More sharing options...
Tido 187 Posted November 12, 2017 Share Posted November 12, 2017 I found it now: "I'm not interested in exploring better 'emergency situation' behaviour but in enabling SBC with low memory to make better use of available DRAM. I mean: that's what zram has been invented for on Android devices: Cope with low memory situations and avoid swapping to slow flash." In this thread I don't understand why VM (virtual machine (I guess)) is always a topic on SBC. That said, it is hard for me to follow in your conclusion. What I can see though Whereas Zador is afraid of implementing problems to armbian: This way it would be easy to disable individual components of Armbian that may not be needed or that may interfere with other services (i.e. your "activate_zram" function checks only for zram-config package and it would interfere with systemd-swap installed by users without an easy way to disable it (since any changes to armhwinfo will be lost on upgrade)). TK wants to take measure with regard to fears of Zador by: Experienced users who know what they do, can be encouraged by another forum thread to start experimenting with zram on their installations Sounds to me, like you both want the best - and while I was writing this Zador added the above posting. Link to post Share on other sites More sharing options...
Regis Michel LeClerc 0 Posted December 31, 2017 Share Posted December 31, 2017 Hi, Well, I'm not sure if it's a bug or what (when gcc crashes, it says to report it as a bug), but I was trying to compile Monero on an Orange Pi PC2 (yeah, pointless, I know, but just for the PoC) and the memory (and lack of swap) came up. Here's my config: root@orangepipc2:~/monero# uname -a Linux orangepipc2 4.14.7-sunxi64 #38 SMP Mon Dec 18 00:49:34 CET 2017 aarch64 aarch64 aarch64 GNU/Linux root@orangepipc2:~/monero# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc2 BOARD_NAME="Orange Pi PC2" BOARDFAMILY=sun50iw2 VERSION=5.37.171218 LINUXFAMILY=sunxi64 BRANCH=next ARCH=arm64 IMAGE_TYPE=nightly BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image Swapiness is configured as follows (looks good to me): root@orangepipc2:~/monero# sysctl -A 2>&1 | grep swap vm.swappiness = 60 and my zram is configured as follows: root@orangepipc2:~/monero# swapon NAME TYPE SIZE USED PRIO /dev/zram0 partition 124.3M 124.2M 5 /dev/zram1 partition 124.3M 124.2M 5 /dev/zram2 partition 124.3M 124.2M 5 /dev/zram3 partition 124.3M 124.2M 5 Ready to compile!... Huh? No. Running make (even "make -j1"!), the thing froze every time and took ages before I could ssh again (I'm not fond of unplugging it and the power-off button seems software-controlled, just like the LEDs, not a NMI, just as frozen as the OPiPC2 itself). It's so frozen that there's "no route to host" when I try to ssh or ping it (I keep it headless, there's nothing plugged on the USBs). The nohup.out shows that, within seconds, the situation comes to a point where cc1 is killed. Pretty ungood, isn't it? Initially, I thought it was CPU over-usage, but htop showed me it actually was the memory getting completely filled, and then the swap (but is it swap or zram in that case? there's no swap configured...). So, yeah, I know, it's not clean to configure swap on a SDCard, but: fallocate /var/swap.file --length 8GB ; chmod 0600 /var/swap.file ; mkswap /var/swap.file ; swapon /var/swap.file ; nohup make -j3 & Initially, I tried just 1GB, bringing total swap to 1.42GB, but htop showed it was eaten up in a matter of a couple of minutes, so I went directly to 8GB. At the moment, load average is at 4.17, swap is 2.15G of 7.94G (well beyond anything I could get without configuring a swap). It's not very reactive (to say the least), but it's working. So, unless there's a way to tell make/cmake//gcc to do otherwise, or a "cleaner" way to get the same result, adding a big swap on the SDCard was the only way to get things done... Slowly, wrongly, but done. Cheers, Regis Link to post Share on other sites More sharing options...
tkaiser 1646 Posted May 17, 2018 Author Share Posted May 17, 2018 Follow-Up on https://www.cnx-software.com/2018/05/13/how-to-get-started-with-opencl-on-odroid-xu4-board-with-arm-mali-t628mp6-gpu/ It's about a compile job requiring up to 3 GB memory. Jean-Luc tested on an ODROID-XU4 with 2 GB RAM so he had to add 1 GB swap since otherwise compilation failed. It's 2018 and we all should know that swap on HDD is anachronistic or even stupid. But Linux users still do it since they did it already one or even two decades ago. Time for a 'quick' benchmark: I test on a board that is even more limited with regard to physical RAM: It's a freshly arrived NanoPi Fire3 with eight A53 cores but just 1 GB RAM so very likely to run in out of memory situations with compile jobs running on all 8 cores in parallel. I used an Armbian Stretch image running with kernel 4.14.40 and configured 2.5 GB swap (either as /var/swap or zram). Also vm.swappiness is set to the default (60). When compiling the job I've seen over 2.3 GB swap being used while building with zram with an average 3.5:1 compression ratio: root@nanopim3:/home/tk# zramctl NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram0 lz4 495.3M 370.1M 99.3M 104.5M 8 [SWAP] /dev/zram1 lz4 495.3M 370.2M 99.4M 104.5M 8 [SWAP] /dev/zram2 lz4 495.3M 371.3M 99.8M 105M 8 [SWAP] /dev/zram3 lz4 495.3M 368.8M 99.1M 104.2M 8 [SWAP] /dev/zram4 lz4 495.3M 370.2M 99.4M 104.5M 8 [SWAP] First tests were with zram (trying to compare lzo with lz4), then I used a swap file on ext4 formatted SD card (a fast A1 rated one and not 'the average SD card' showing magnitudes lower random IO performance). Afterwards I tested with an older 7200rpm notebook HDD and then a Samsung EVO 840 both attached via USB2 without UAS support (so both random and sequential IO are bottlenecked by USB2 -- 'typical SBC conditions'). Filesystem used was a freshly created ext4 so no performance difference between swap file and partition. Benchmark execution as follows: I deleted the working directory, then untared the archive (see above) and then let the following run: time scons Werror=1 -j8 debug=0 neon=1 opencl=1 embed_kernels=1 os=linux arch=arm64-v8a build=native Results: zram lzo 46m57.427s zram lz4 47m18.022s SSD 144m40.780s SanDisk Ultra A1 16 GB 247m56.744s HDD 570m14.406s Using zram is a no-brainer. The job finished within 47 minutes with both lzo and lz4 compression scheme. When testing with swap on real storage for obvious reasons the SSD won (best random IO performance), then the A1 rated SD card could finish the job in 4 hours and of course swap on HDD failed miserably since spinning rust simply sucks when it's about random I/O performance. Swap on HDD is BS. A device with 1 GB physical DRAM is able to perform a build job requiring 3 GB memory within 47 minutes when using modern approaches (zram), when doing it like we did it last century (swapping to storage) then it's all about random I/O performance. A great performing SSD even if bottlenecked by USB2 is able to finish the job in less than two and a half hours. An el cheapo SanDisk Ultra A1 SD card with 16 GB scores 4 hours while as expected a 7.2k notebook HDD takes almost 10 hours to do the same job. HDDs suck at random IO. Period. What can we learn from this? Nothing since Armbian is only focused on adding more and more irrelevant boards to the build system instead of improving situation for all boards. As a reference iozone numbers for the 3 storage scenarios: SanDisk Ultra A1 random random kB reclen write rewrite read reread read write 102400 4 3677 3856 9344 9320 8070 2787 102400 16 3890 7780 16398 16216 14832 6716 102400 512 9925 13902 22494 22501 22411 13178 102400 1024 13826 13750 22651 22649 22640 13792 102400 16384 14031 13936 23141 23137 23163 15395 Hitachi 2.5" 7200 rpm random random kB reclen write rewrite read reread read write 102400 4 7537 9837 8016 7763 671 1119 102400 16 17452 20618 20852 20997 2522 4250 102400 512 33123 33403 34165 34756 25589 32262 102400 1024 33580 33310 34331 35056 29620 33148 102400 16384 32592 33804 34921 35591 35277 33838 Samsung EVO 840 SSD random random kB reclen write rewrite read reread read write 102400 4 7322 9481 9636 9682 7433 9496 102400 16 16654 19453 18576 18639 18301 19370 102400 512 31296 31489 32778 32876 32977 31337 102400 1024 31016 31986 33334 34283 33991 31273 102400 16384 30600 31336 33318 33678 33236 31913 1 Link to post Share on other sites More sharing options...
TonyMac32 560 Posted May 18, 2018 Share Posted May 18, 2018 4 hours ago, tkaiser said: Swap on HDD is BS My 1992 Conner hard drive is weeping. Nice write-up. Link to post Share on other sites More sharing options...
tkaiser 1646 Posted May 18, 2018 Author Share Posted May 18, 2018 4 hours ago, TonyMac32 said: Nice write-up And just a waste of time... Link to post Share on other sites More sharing options...
Tido 187 Posted May 18, 2018 Share Posted May 18, 2018 11 hours ago, tkaiser said: But Linux users still do it since they did it already one or even two decades ago. Well, it could soon be back in fashion, NVMe and other technologies just around the corner. Not true for our SBC's of course! 11 hours ago, tkaiser said: What can we learn from this? Nothing since Armbian is only focused on adding more and more irrelevant boards to the build system instead of improving situation for all boards. while this seems to me off topic - except you want to express. "why do you spend time on new SBCs instead of getting the build-system to the latest and fastest technology for devices with limited HW" :-) @Igor, @zador.blood.stained, any chance to expand the usage of ZRAM or are there still technical roadblocks ahead ? Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted May 18, 2018 Share Posted May 18, 2018 6 minutes ago, Tido said: @zador.blood.stained, any chance to expand the usage of ZRAM What do you mean by that exactly? zram for the build host or for built OS images? 7 minutes ago, Tido said: are there still technical roadblocks ahead ? If lack of a proper build HW counts as a technical roadblock (in addition to existing problems like a time bomb log2ram implementation and non-technical project goals/aims and resulting motivation) then yes. Link to post Share on other sites More sharing options...
JMCC 356 Posted May 18, 2018 Share Posted May 18, 2018 FWIW, I've been doing lately lots of compiling in devices with 2Gb of RAM (TB, XU4), including big projects that recommended 4Gb for compilation (e.g. Collabora CODE), and never ran out of memory with the current ZRAM implementation. Of course, the situation could be different with devices having less RAM. [UPDATE:] As a matter of fact, I set up an additional swapfile in the external SSHD, just to be safe, and never got used: Spoiler $ cat /proc/swaps Filename Type Size Used Priority /dev/zram0 partition 127612 11516 5 /dev/zram1 partition 127612 11492 5 /dev/zram2 partition 127612 11684 5 /dev/zram3 partition 127612 11552 5 /dev/zram4 partition 127612 11720 5 /dev/zram5 partition 127612 11448 5 /dev/zram6 partition 127612 11668 5 /dev/zram7 partition 127612 11600 5 /mnt/externo/swapfile1 file 2097148 0 -1 Link to post Share on other sites More sharing options...
Tido 187 Posted May 18, 2018 Share Posted May 18, 2018 13 minutes ago, zador.blood.stained said: zram for the build host or for built OS images? I meant for the images people download. IIRC I read from TK somewhere that ZRAM is only used on Debian or Ubuntu, why not on both? 15 minutes ago, zador.blood.stained said: If lack of a proper build HW counts as a technical roadblock A while ago I read about a big server of Igor which does compilation of the images. Is this not running properly for such tasks ? 17 minutes ago, zador.blood.stained said: like a time bomb log2ram implementation I wanted to ask you about that in April, but I couldn't find the thread where you started with an idea that needs some testing. Can you create .deb for testing and the users here can do testing for you and reporting to you ? 20 minutes ago, zador.blood.stained said: non-technical project goals/aim Can you name one or two ? Rome wasn't built in a day.. Link to post Share on other sites More sharing options...
zador.blood.stained 765 Posted May 18, 2018 Share Posted May 18, 2018 12 minutes ago, Tido said: IIRC I read from TK somewhere that ZRAM is only used on Debian or Ubuntu, why not on both? Because zram-config package exists only in Ubuntu by default, and for reasons I don't remember (probably version numbering / potential repository priority issues?) we decided to not copy it to our repository to be available for all releases. 12 minutes ago, Tido said: Is this not running properly for such tasks ? It's not set up for multi-user scenario yet (VM guests for different tasks and users instead of one shared space otherwise manual build tasks may conflict with automated ones) 12 minutes ago, Tido said: Can you name one or two ? Rome wasn't built in a day.. I meant this specific thread: https://forum.armbian.com/topic/6281-board-support-general-discussion-project-aims/ Recent examples to add to that - there is no purpose in recently added "development" branch if "master" is completely abandoned as a result and suggesting to "switch to beta" to fix any issues defeats the purpose of "beta" - fixes should be immediately pushed to the stable branch and beta should be left for non-production ready stuff. 1 Link to post Share on other sites More sharing options...
JMCC 356 Posted May 18, 2018 Share Posted May 18, 2018 My two cents, as a rookie: maybe it is a good idea to finish all the work for the meant-to-be-soon release, and then discuss about necessary changes in the project structure/aims. Link to post Share on other sites More sharing options...
