image build problems with custom package-ref/upstream version
  I’m trying to integrate the newly released hostapd 2.7 into an image and I’m having trouble including it as a part of the image build process (bionic on vagrant - by the book). My tree is a few weeks out of date, but I can’t see any subsequent commits to the scripts that seem to be the source of my trouble.
My build config is:
KERNEL_ONLY="no"
KERNEL_CONFIGURE="no"
CLEAN_LEVEL="make,debs,oldcache"
DEST_LANG="en_US.UTF-8" # sl_SI.UTF-8, en_US.UTF-8
KERNEL_KEEP_CONFIG="no" # do not overwrite kernel config before compilation
EXTERNAL="yes"          # build and install extra applications and drivers
EXTERNAL_NEW="compile"  # compile and install or install prebuilt additional packages
CREATE_PATCHES="no"
BUILD_ALL="no"
BSPFREEZE=""
INSTALL_HEADERS=""
BOARD="nanopineo"
BRANCH="next"
RELEASE="stretch"
Additionally, I’ve change packages/extras-buildpkgs/90-hostapd.conf to have
local package_ref="tag:hostap_2_7"
local package_upstream_version="3:2.7-00"
And have removed the patches under packages/extras-buildpkgs/hostapd/debian/patches.
During the build, I see the 2.7-00 package being loaded into the temporary repo created in chroot_installpackages_local
Local repo [temp] successfully added.
You can run 'aptly repo add temp ...' to add packages to repository.
Loading packages...
[+] xserver-xorg-video-armsoc-sun4i_1.4.1~armbian5.65+1_armhf added
Loading packages...
[+] hostapd-realtek_3:2.5-1~armbian5.65+1_arm64 added
[+] hostapd-realtek_3:2.5-1~armbian5.65+1_armhf added
[+] hostapd_3:2.7-00~armbian5.65+1_arm64 added
[+] hostapd_3:2.7-00~armbian5.65+1_armhf added
[+] mmc-utils_0~gita3d3331-3~armbian5.65+1_arm64 added
[+] mmc-utils_0~gita3d3331-3~armbian5.65+1_armhf added
[+] sunxi-tools_1.4.2-2~armbian5.65+1_arm64 added
[+] sunxi-tools_1.4.2-2~armbian5.65+1_armhf added
But then see errors when setting up the temporary repo:
Generating metadata files and linking package files...
Finalizing metadata files...
Signing file 'Release' with gpg, please enter your passphrase when prompted:
gpg: WARNING: unsafe ownership on homedir '/home/vagrant/.gnupg'
gpg: WARNING: "--no-use-agent" is an obsolete option - it has no effect
gpg: skipped "925644A6": No secret key
gpg: signing failed: No secret key
ERROR: unable to publish: unable to detached sign file: exit status 2
[ .... ] Installing additional packages [ EXTERNAL_NEW ]
No published repositories, unable to serve.
OK
Err:1 http://localhost:8189 stretch InRelease
  Could not connect to localhost:8189 (127.0.0.1). - connect (111: Connection refused) [IP: 127.0.0.1 8189]
Subsequently it is unable to find the 2.7 deb and hostapd stays at armbian’s 2.6-99
Reading package lists...
W: Failed to fetch http://localhost:8189/dists/stretch/InRelease  Could not connect to localhost:8189 (127.0.0.1). - connect (111: Connection refused) [IP: 127.0.0.1 8189]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
hostapd is already the newest version (3:2.6-99~armbian5.60+1).
Can anyone suggest what might be happening here, and where I might look next as I try to resolve this? It’s the first time I’ve tried to compile extra applications but I can’t find anything in the doco or forum that seems related to this situation.
Thanks,
Edwin.
Thank you, Igor.
When I get it building successfully, and have done some testing, would there be appetite for a PR to bump the Armbian version to 2.7?
I've rebased my branch and pulled in commits up to b4e5c589169a076dc081c101448b35cff26b6f12 (Dec 6) and I'm seeing the same problem i.e.
Loading packages...
[+] xserver-xorg-video-armsoc-sun4i_1.4.1~armbian5.67+1_armhf added
Loading packages...
... snip
[+] sunxi-tools_1.4.2-2~armbian5.67+1_armhf added
Loading packages...
It's reproducible in the VM (without going through the build process each time), and poking around further I wonder whether something's wrong with the secret keyring:
root@vagrant:/home/vagrant/armbian# gpg --no-default-keyring --keyring packages/extras-buildpkgs/buildpkg.gpg --list-keys
gpg: DBG: FIXME: merging secret key blocks is not anymore available
gpg: Oops; key lost!
gpg: DBG: node 0x000055f20ab67cd0 01/00 type=secret-key
gpg: DBG: node 0x000055f20ab67e10 00/00 type=user-id  "Armbian builder (Temporary key for installing packages during Armbian image creation) <root@localhost>" ....
gpg: DBG: node 0x000055f20ab67fc0 00/00 type=signature  class=13 keyid=925644A6 ts=1470410930
gpg: DBG: node 0x000055f20ab6a7a0 00/00 type=secret-subkey
gpg: DBG: node 0x000055f20ab6ab60 00/00 type=signature  class=18 keyid=925644A6 ts=1470410930
root@vagrant:/home/vagrant/armbian# gpg --no-default-keyring --keyring packages/extras-buildpkgs/buildpkg.gpg --list-secret-keys
I'm quite unfamiliar with GPG, so it's possible I'm way off track but the "Oops; key lost!" is consistent with the inability for aptly to publish because it can't find the secret key.
Any suggestions?
I am not sure this part of the script - rebuilding packages - were tested in anything that native environment. Not sure for Vagrant, but for Docker this is disabled out of the box:
[ warn ] EXTERNAL_NEW=compile is not available when running in container, setting to prebuilt
It works for me on KVM host.
If there are no issues, sure, why not. I hope all our patches also apply?
