Hello
Could You advice how to steering my GPIO output
I need set "+" for this 4 canal 31 33 35 37
I already have the connect but can`t fine tutorial on web how to do it.
You could use gpio sysfs as it is the most easy way.
pin31,33,35,37 are respectively PB5,PB6,PB7 and PD5. In gpio sysfs, they becomes gpio37,gpio38,gpio39 and gpio101.
Here are the command to turn a gpio37 into output and set level output state :
echo 37 > /sys/class/gpio/export
echo "out" > /sys/class/gpio37/direction
echo 1 > /sys/class/gpio37/value
Simply repeat the code for other gpios ...
7 minutes ago, djmcg said:
Look`s like not work
Sorry, I did some typos, it should be :
echo "out" > /sys/class/gpio/gpio37/direction
echo 1 > /sys/class/gpio/gpio37/value
8 minutes ago, martinayotte said:
Simple ...
echo 0 > /sys/class/gpio/gpio37/value
Hello I just  tested with parameter "0" not work, but
  - init option to work (on ,off)
  - turn On
   - turn Off
Thank You
6 minutes ago, djmcg said:
now 0 work correctly
Good !
Simple bash script to toogle every half seconds :
#!/bin/bash
while true; do
	sleep 0.5
	sleep 0.5
done
Could You help me
When i turn on/off the 37 port in
gpio readall
The port 31 is change
Could You advice what`s happen
see screen
What do you means, there is no such pins for 31, neither than 29,33,35, gpio numbers are the ones in the BCM column ... So that is why sysfs gives errors.
For "gpio readall" outputs, it is reflecting the reality when you change value of 37, the V columns is appearing accordingly...
