timsan Posted December 26, 2018 Posted December 26, 2018 I just tried to get the dhclient on eth0 to communicate with my ISP (which uses dhcp). On OpenWrt, this works with no problem. However, all I got on the bpi-r2 (eth0) was a 169.x (no answer) address. For the internal network, the dhclient works just fine. I have already tried using eth0 in systemd's network and outside of it (using dhclient). No communication in both cases. ta, t.
Tido Posted December 26, 2018 Posted December 26, 2018 On 12/26/2018 at 12:01 AM, timsan said: No communication in both cases Expand please post the armbianmonitor -u output However, I recommend, if you haven't already, read this: https://forum.armbian.com/topic/7296-bananapi-r2-csc-mt7623-as-new-boardfamily/
timsan Posted January 2, 2019 Author Posted January 2, 2019 Sorry for the delay. http://ix.io/1xj8 I attempted this on Dec 25, when the network was free to mess with. ta t
chwe Posted January 2, 2019 Posted January 2, 2019 as far as I know, openWRT uses still the 4.9 kernel right? And if I'm not completely wrong the 4.9 kernel uses not a DSA driver. Maybe @frank-w can comment on this cause he knows the BSP sources a way better than I do. I only did the 'board bring up' with mainline kernels (starting somewhere at 4.17 now at 4.19).. DSA is actually a bit messy at the moment and it's not that easy to give you some guidance (e.g. I've fiber so I can't test a lot of things..) eth0 isn't really 'wired out'.. in a picture eth0 are the traces between the SoC and the DSA chip (mt7530). So I assume (and that's pure assumptions) it's likely a configuration issue. The current configuration (https://github.com/armbian/build/tree/master/packages/bsp/mt7623) might not be sufficient for you (it's a it just works configuration and there's a lot room for improvements ). Maybe pick out one interface (e.g. wan) from the bridge and give it a try?
frank-w Posted January 2, 2019 Posted January 2, 2019 official lede from sinovoip still uses 4.9, but there is imho also a dsa-driver (backported from 4.1x afair), there is openwrt with 4.14 which includes Patches for bpi-r2 (where i've got my Patches for second gmac). if you have a dsa-driver (you see interfaces wan,lan0-lan3) you cannot work on eth0/eth1 (these are only the ethernet-connections between switch [mt7530] and SOC/Main-CPU [mt7623]), only bring them up...ip-config has to be done on dsa-interfaces. 1
Tido Posted January 2, 2019 Posted January 2, 2019 DSA, VLAN, Bridge ... so much to learn for Lamobo R1 "Slide 4" represents basically the DSA setup: https://docs.google.com/presentation/d/1GMGeXn3iX1tCwCTh4oVmHh-SE-XFfbxxH-6wjigV3RI/edit#slide=id.g2191e74569_0_0 I wrote a doc about it... https://docs.google.com/document/d/1DH8AXCHqUYI6J4L4ujt20aI9BNrYxsWtcthWZEJx8Xs/edit#
frank-w Posted January 2, 2019 Posted January 2, 2019 you have not to care about DSA, only that it is there and you have to operate on virtual interfaces wan,lan0-3 instead of ethx. vlan have also time (most people don't need it), first get basic network-setup working. so just bring eth0/1 only up and configure the wan/lan-ports btw. it's new to me that there is a DSA-Driver for Bpi-R1, i only have seen swconfig-configurations to access ports separately
chwe Posted January 2, 2019 Posted January 2, 2019 that's why I highlighted you here.. you know the BSP and 'out of armbian' world better for the R2 than me. For the R2 Armbian uses networkd for configuration the best tutorials I found for it is found in archs wiki (they should print it in a book and call it linux for dummies ) https://wiki.archlinux.org/index.php/systemd-networkd Currently I don't spend much time in the R2, it's just that time is limited. I had a patch prepared for the second gmac (based on franks work), it shows up in ip a but networkd doesn't like it.. Maybe I've a look into it in the next weeks.
