Cubieboard 2: Armbian 5.3 Ubuntu Xenial - repository issues?
Hi
After doing a clean install to SD card of armbian 5.3 Ubuntu Xenial, I see multiple failures to install packages like Docker and Gitlab via apt-get.
In both instances, I follow instructions as per the official pages, but when I try to do the installation, apt-get will report that "E: Package 'docker-ce' has no installation candidate" for example, even though it is present searching in the cache.
Am I doing something wrong - perhaps I need another repository source?
On 1/5/2019 at 7:58 AM, Piie said:
Hi
I suspect you were trying to do this with a kernel 3.4.y? That one is waaay too old for Docker.  Whenever you are asking for help, please do provide logs that we know what you are talking about. Type:
armbianmoninor -u
and try to use armbian-config way of installing Docker which is tested way. But it can also be something else, like network related problems?
Hi
http://ix.io/1xNO
Yes, it looks like it is still 3.4.11 - which appeared to be the latest link on the armbian site for Cubiebord 2. Is it possible to update it?
Also, I cannot find a Docker install option under any of the menu items in armbian-config?
