Piie Posted January 5, 2019 Posted January 5, 2019 Hi After doing a clean install to SD card of armbian 5.3 Ubuntu Xenial, I see multiple failures to install packages like Docker and Gitlab via apt-get. In both instances, I follow instructions as per the official pages, but when I try to do the installation, apt-get will report that "E: Package 'docker-ce' has no installation candidate" for example, even though it is present searching in the cache. Am I doing something wrong - perhaps I need another repository source?
Igor Posted January 8, 2019 Posted January 8, 2019 On 1/5/2019 at 6:58 AM, Piie said: Hi After doing a clean install to SD card of armbian 5.3 Ubuntu Xenial, I see multiple failures to install packages like Docker and Gitlab via apt-get. In both instances, I follow instructions as per the official pages, but when I try to do the installation, apt-get will report that "E: Package 'docker-ce' has no installation candidate" for example, even though it is present searching in the cache. Am I doing something wrong - perhaps I need another repository source? Expand I suspect you were trying to do this with a kernel 3.4.y? That one is waaay too old for Docker. Whenever you are asking for help, please do provide logs that we know what you are talking about. Type: armbianmoninor -u and try to use armbian-config way of installing Docker which is tested way. But it can also be something else, like network related problems?
Piie Posted January 8, 2019 Author Posted January 8, 2019 Hi http://ix.io/1xNO Yes, it looks like it is still 3.4.11 - which appeared to be the latest link on the armbian site for Cubiebord 2. Is it possible to update it?
Piie Posted January 8, 2019 Author Posted January 8, 2019 Also, I cannot find a Docker install option under any of the menu items in armbian-config?
