littlema Posted January 15, 2019 Share Posted January 15, 2019 Here I found a bug in Nanopi M4. When I download BitTorrent file through ipv6(use Transmission,qbittorent...),the network will crashed. And I even can't ping it successful. When I connect it in local.I don't see any log in the network service. And when I replace the network card(1000Mb) with a usb network card. The network work very good.And didn't appear any problem. I have try all the linux system include the office system. the problem happen again. So I only can use the usb network card or wifi. Does anyone who know how to solve the problem??? I would be very grateful for it. I noticed a same problem in firely board. if it is the same problem?? http://dev.t-firefly.com/thread-11741-2-1.html and he change the kernel in this way: &gmac { phy-supply = <&vcc_phy>; phy-mode = "rgmii"; clock_in_out = "input"; snps,reset-gpio = <&gpio3 15 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 50000>; assigned-clocks = <&cru SCLK_RMII_SRC>; assigned-clock-parents = <&clkin_gmac>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; tx_delay = <0x28>; - rx_delay = <0x11>; + rx_delay = <0x1B>; status = "okay"; }; I don't know if it work. And I didn't know how to change it in the kernel files. I am poor in this work. I also find that the nanopi m4 use the st_gmac driver for eth0 1000m. And I'm sure it has some bug. When I use the usb card drvier for usb card.Every thing work good. Link to comment Share on other sites More sharing options...
