I am using the latest Armbian image on OPI+.
I had a requirement to read a 64Gb USB flash formatted under Windows with the extFat filesystem.
Much to my surprise it didn't mount. I thought it was a hardware problem 1st. But then it appeared, that mount doesn't support the the extFat filesystem by default.
It is necessary to add the extra packages, but I didn't succeed:
root@orangepiplus:/# apt-get install exfat-fuse exfat-utils
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 9 not upgraded.
Need to get 66.9 kB of archives.
After this operation, 198 kB of additional disk space will be used.
Err http://httpredir.debian.org/debian/ jessie/main exfat-fuse armhf 1.1.0-2+deb8u1
Could not resolve 'httpredir.debian.org'
Err http://httpredir.debian.org/debian/ jessie/main exfat-utils armhf 1.1.0-2+deb8u1
E: Failed to fetch http://httpredir.debian.org/debian/pool/main/f/fuse-exfat/exfat-fuse_1.1.0-2+deb8u1_armhf.deb Could not resolve 'httpredir.debian.org'
E: Failed to fetch http://httpredir.debian.org/debian/pool/main/e/exfat-utils/exfat-utils_1.1.0-2+deb8u1_armhf.deb Could not resolve 'httpredir.debian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I switched to the OpenElec, which mounted the extFat nicely alone with the Fat32:
/dev/sdb1 29.5G 29.5G 0 100% /var/media/TF29GB
/dev/sdc1 58.0G 47.8G 10.3G 82% /var/media/USB58GB
OpenELEC:~ # cat /etc/mtab
/dev/sdb1 /var/media/TF29GB vfat rw,nosuid,nodev,noexec,noatime,fmask=0133,dmask=0022,codepage=cp437,iocharset=ascii,shortname=mixed,utf8,errors=continue 0 0
/dev/sdc1 /var/media/USB58GB fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 0 0
What is the problem installing exfat-fuse exfat-utils ?
The resolve issue was the 1st I thought about.
root@orangepiplus:/usr/src# ping httpredir.debian.org
PING httpredir.debian.org (176.9.184.93) 56(84) bytes of data.
64 bytes from raphael.ganneff.de (176.9.184.93): icmp_seq=1 ttl=46 time=83.6 ms
64 bytes from raphael.ganneff.de (176.9.184.93): icmp_seq=2 ttl=46 time=57.5 ms
Nonetheless, it appears to be the reason. I've retried the
and it succeeded this time.
Now I am able to mount:
root@orangepiplus:/usr/src# mount /dev/sdb1 /mnt/sdb1/
FUSE exfat 1.1.0
/dev/sdb1 /mnt/sdb1 fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096 0 0
/dev/sdb1        59G   33G   26G  57% /mnt/sdb1
Thanks for the prompt again.
