I find quite strange that CONFIG_DM_MIRROR is not set in the kernel. It makes impossible under lvm to have logical volume mirror, and I just experienced an impossibility to make a pvmove to change one drive for another one. All my filesystems are built upon lvm, the only possibility would be to rebuild a kernel. But I find it quite heavy, since I have to platforms bananapi and espressobin; and it needs to be done for each release.
But why no have built dm-mirror as module with the usual CONFIG_DM_MIRROR=m ?
Maybe because no one had a need for it yet.
You can build your own kernel and edit the config using the build script: https://github.com/armbian/build
If you think this might be useful for others feel free to send a PR with the changes to the kernel config so all future builds include this.
perhaps an idea using " compile.sh " and select particular option from kernel ( save .config in user space )
KERNEL_CONFIGURE=yes
Tried build branch twice. Failed atm..
root@orangepione:~# modprobe dm-mirror
modprobe: FATAL: Module dm-mirror not found in directory /lib/modules/5.8.11-sunxi
Seems I need add that into my action.
@Quardex - OPiOne is a H3 board isn't it , well current branch should be fine indeed
Nevertheless perhaps you can give kernel 5.9 a go ( currently rc7, production ready in about 2,5 weeks imho )
Try building with e.g. ( assuming Debian and no Desktop ) :
./compile.sh BRANCH=current RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=yes BOARD=orangepione
Go to kernel configuration and select :
" Device Drivers ",  "   <M> DAX: direct access to differentiated memory "
Uhm DAX was in kernel 5.9 (rc5) an issue if I remember correctly, well your module should be here, also for 5.8 that is no difference :
" Device Drivers " -> ", " Multiple devices driver support (RAID and LVM)  ---> ", " <M> Mirror Target  ".
I just checked out and indeed it is not selected so enable <M> and give it a go.
Perhaps more dependencies needed, I am not sure but you should be able to take your pick and build it according your needs.
It should build and hopefully it helps you out
Atm when I try compile master brunch I got that error:
  CC [M]  drivers/net/wireless/rtl8189es/os_dep/linux/mlme_linux.o
  CC [M]  drivers/net/wireless/rtl8189es/os_dep/linux/recv_linux.o
  CC [M]  drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.o
[ error ] ERROR in function compile_kernel [ compilation.sh:411 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
Tried twice on different computers.
Edited by Quardex
Which board?
Look at output/debug folder and check the compilation.txt for errors.
Try with setting EXTRAWIFI=no
4 hours ago, Werner said:
Which board?
orangepione
With "EXTRAWIFI=no" compiled fine
Log without EXTRAWIFI=no:
output.log:
Displaying message: ERROR in function compile_kernel compilation.sh:411 err
Displaying message: Kernel was not built @host err
Displaying message: Process terminated  info
compilation.log:
In file included from ./include/net/cfg80211.h:21,
                 from drivers/net/wireless/realtek/rtl8723cs/include/osdep_service_linux.h:92,
                 from drivers/net/wireless/realtek/rtl8723cs/include/osdep_service.h:41,
                 from drivers/net/wireless/realtek/rtl8723cs/include/drv_types.h:32,
                 from drivers/net/wireless/realtek/rtl8723cs/hal/phydm/rtl8703b/../phydm_types.h:172,
                 from drivers/net/wireless/realtek/rtl8723cs/hal/phydm/rtl8703b/../phydm_precomp.h:24,
                 from drivers/net/wireless/realtek/rtl8723cs/hal/phydm/rtl8703b/halphyrf_8703b.c:22:
./include/linux/ieee80211.h:1600: note: this is the location of the previous definition
 1600 | #define IEEE80211_MAX_AMPDU_BUF  0x100
In file included from drivers/net/wireless/realtek/rtl8723cs/include/drv_types.h:35,
                 from drivers/net/wireless/realtek/rtl8723cs/core/rtw_mp.c:22:
drivers/net/wireless/realtek/rtl8723cs/include/wifi.h:1009: warning: "IEEE80211_MAX_AMPDU_BUF" redefined
 1009 | #define IEEE80211_MAX_AMPDU_BUF 0x40
                 from drivers/net/wireless/realtek/rtl8723cs/core/rtw_mp_ioctl.c:22:
drivers/net/wireless/rtl8189es/core/rtw_mlme_ext.c: In function ‘mgt_dispatcher’:
drivers/net/wireless/rtl8189es/core/rtw_mlme_ext.c:1093:6: warning: this statement may fall through [-Wimplicit-fallthrough=]
 1093 |    if(check_fwstate(pmlmepriv, WIFI_AP_STATE) == _TRUE)
drivers/net/wireless/rtl8189es/core/rtw_mlme_ext.c:1098:3: note: here
 1098 |   case WIFI_ASSOCREQ:
drivers/net/wireless/rtl8189es/core/rtw_iol.c: In function ‘rtw_IOL_cmd_buf_dump’:
drivers/net/wireless/rtl8189es/core/rtw_iol.c:261:3: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
  261 |   if(j%32 ==0) printk("\n");j++;
drivers/net/wireless/rtl8189es/core/rtw_iol.c:261:29: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c:6549:37: error: ‘cfg80211_rtw_mgmt_frame_register’ undeclared here (not in a function)
 6549 |  .update_mgmt_frame_registrations = cfg80211_rtw_mgmt_frame_register,
make[4]: *** [scripts/Makefile.build:281: drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.o] Error 1
make[3]: *** [scripts/Makefile.build:497: drivers/net/wireless/rtl8189es] Error 2
make[2]: *** [scripts/Makefile.build:497: drivers/net/wireless] Error 2
make[1]: *** [scripts/Makefile.build:497: drivers/net] Error 2
make: *** [Makefile:1754: drivers] Error 2
Edited by Quardex
After clearing the cache the same error:
Need someone else to check it.
Edited by Quardex
No idea. Just built kernel package for OPi1 flawless including WiFi drivers.
- are you using official master branch?
- is it up to date? git pull
We have an automated job which runs whenever things are changed to detect errors and there are none atm.
Nope, it wasn't.
After update the compilation was successful and the module worked properly.
Thank you all!
Last question:
https://www.armbian.com/donate/
Is this variant actual to make donation?
Edited by Quardex
