Issue found!
Orange PI changed eMMC from KLM8G1GETF to KLM8G1WEPD. The difference is eMMC 5.0 vs 5.1 and maybe more. The key things is that Armbian (checked using 5.35 and the latest one) does not see this memory (fdisk -l)!!
I have noticed it on OPI0 Plus 2 H3. PCB boards are the same, only memory model no. difference. Someone solved it or noticed the same?
Confused 🤨
Are you sure it is related to chip models ? Did you have check the logs with "dmesg | grep -i mmc" ?
I am sure -  I have 100 pcs of this boards. Sold already 1000 with KLM8G1GETF -  no issues. The latest batch has different memory chip and I do not see this memory in fdisk -l. The old boards indicate eMMC memory.
[    0.000000] Kernel command line: root=UUID=8591b60d-2481-4c21-806f-a9146bdb782f rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=cd93fc55-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=96M  cgroup_enable=memory swapaccount=1
[    1.213356] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Nov 22 2017 at 13:44:04
[    1.213395] [mmc]: get mmc0's sdc_power is null!
[    1.213424] [mmc]: get mmc1's sdc_power is null!
[    1.213434] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.213443] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.213473] [mmc]: get mmc2's sdc_power is null!
[    1.213483] [mmc]: get mmc2's 2xmode ok, val = 1
[    1.213492] [mmc]: get mmc2's ddrmode ok, val = 1
[    1.213505] [mmc]: MMC host used card: 0x7, boot card: 0x0, io_card 2
[    1.217283] [mmc]: sdc0 power_supply is null
[    1.329173] mmc0: new high speed SDHC card at address aaaa
[    1.329733] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.332534]  mmcblk0: p1
[    1.333183] mmcblk mmc0:aaaa: Card claimed for testing.
[    1.333199] mmc0:aaaa: SC16G 14.8 GiB
[    1.334782] [mmc]: sdc2 power_supply is null
[    1.472884] mmc2: unrecognised EXT_CSD revision 8
[    1.472905] mmc2: error -22 whilst initialising MMC card
[    1.473035] [mmc]: sdc2 power_supply is null
[    1.477145] [mmc]: sdc2 power_supply is null
[    1.567456] mmc2: unrecognised EXT_CSD revision 8
[    1.567488] mmc2: error -22 whilst initialising MMC card
[    1.567643] [mmc]: sdc2 power_supply is null
[    1.571824] [mmc]: sdc2 power_supply is null
[    1.675883] mmc2: unrecognised EXT_CSD revision 8
[    1.675919] mmc2: error -22 whilst initialising MMC card
[    1.676074] [mmc]: sdc2 power_supply is null
[    1.680111] [mmc]: sdc2 power_supply is null
[    1.804071] mmc2: unrecognised EXT_CSD revision 8
[    1.804109] mmc2: error -22 whilst initialising MMC card
[    1.804260] [mmc]: sdc2 power_supply is null
[    1.808537] [mmc]: sdc1 power_supply is null
[    1.858522] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.860256] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.862010] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.865025] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.868606] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[    1.965277] mmc1: new high speed SDIO card at address 0001
[    8.127876] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   10.695377] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   10.850354] dummy_sdmmc: probe of mmc1:0001:1 failed with error -123
[   10.850409] dummy_sdmmc: probe of mmc1:0001:2 failed with error -123
[   10.850649] mmc1: card 0001 removed
[   10.850954] [mmc]: sdc1 power_supply is null
[   10.855213] [mmc]: sdc1 power_supply is null
[   10.907235] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[   10.908787] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   10.910345] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   10.913116] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[   10.916502] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[   11.002973] mmc1: new high speed SDIO card at address 0001
[   11.019839] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[   11.019933] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
Here you go.
And the same command on Samsung memory (eMMC was detected):
[    1.223368] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Nov 22 2017 at 13:44:04
[    1.223406] [mmc]: get mmc0's sdc_power is null!
[    1.223436] [mmc]: get mmc1's sdc_power is null!
[    1.223445] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.223454] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.223484] [mmc]: get mmc2's sdc_power is null!
[    1.223493] [mmc]: get mmc2's 2xmode ok, val = 1
[    1.223502] [mmc]: get mmc2's ddrmode ok, val = 1
[    1.223516] [mmc]: MMC host used card: 0x7, boot card: 0x0, io_card 2
[    1.227308] [mmc]: sdc0 power_supply is null
[    1.339175] mmc0: new high speed SDHC card at address aaaa
[    1.339742] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.342545]  mmcblk0: p1
[    1.343211] mmcblk mmc0:aaaa: Card claimed for testing.
[    1.343227] mmc0:aaaa: SC16G 14.8 GiB
[    1.344811] [mmc]: sdc2 power_supply is null
[    1.464544] mmc2: new high speed DDR MMC card at address 0001
[    1.465129] mmcblk1: mmc2:0001 8WPD3R 7.28 GiB
[    1.465380] mmcblk1boot0: mmc2:0001 8WPD3R partition 1 4.00 MiB
[    1.465617] mmcblk1boot1: mmc2:0001 8WPD3R partition 2 4.00 MiB
[    1.466642]  mmcblk1: p1
[    1.469477]  mmcblk1boot1: unknown partition table
[    1.471042]  mmcblk1boot0: unknown partition table
[    1.471271] mmcblk mmc2:0001: Card claimed for testing.
[    1.471284] mmc2:0001: 8WPD3R 7.28 GiB
[    1.472856] [mmc]: sdc1 power_supply is null
[    1.528224] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.529882] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.531514] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.534440] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.631553] mmc1: new high speed SDIO card at address 0001
[    8.337376] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   11.001099] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   11.070301] dummy_sdmmc: probe of mmc1:0001:1 failed with error -123
[   11.070349] dummy_sdmmc: probe of mmc1:0001:2 failed with error -123
[   11.070557] mmc1: card 0001 removed
[   11.070816] [mmc]: sdc1 power_supply is null
[   11.074947] [mmc]: sdc1 power_supply is null
[   11.127956] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[   11.129516] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   11.131107] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   11.133882] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[   11.224041] mmc1: new high speed SDIO card at address 0001
[   11.240329] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[   11.240449] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
I think this is the bottom of the issue.
But I don't know how to fix it ...
EDIT : it seems that it is already fixed : https://github.com/armbian/build/commit/dcedd6c2ec102a9524b140604ce301b67cbbd27a
EDIT2 : This means that you are using a pretty old image since this fix in Legacy is present since more than a year ...
