Charizard Posted January 22, 2019 Posted January 22, 2019 Hello, In december, it was possible to install 4.19 kernel for Rock64. Unfortunately this kernel was removed from Armbian repo. 4.20 kernel is bogus, USB doesn't work and SD card is very slow. 4.19 was fine. Is it possible to make it available again in in the repo ? Thank you
martinayotte Posted January 22, 2019 Posted January 22, 2019 On 1/22/2019 at 8:16 PM, Charizard said: Is it possible to make it available again in in the repo ? Expand NEXT changed from 4.14.y to 4.19.y DEV changed from 4.19.y to 4.20.y So, simply use NEXT ...
Igor Posted January 22, 2019 Posted January 22, 2019 On 1/22/2019 at 8:34 PM, martinayotte said: NEXT changed from 4.14.y to 4.19.y DEV changed from 4.19.y to 4.20.y So, simply use NEXT ... Expand Not for Rock64 We don't have this kernel in a BETA repo anymore since we keep only last n versions.
martinayotte Posted January 22, 2019 Posted January 22, 2019 On 1/22/2019 at 8:45 PM, Igor said: Not for Rock64 Expand Right ! sometimes, my memory is too volatile ... On 1/22/2019 at 8:16 PM, Charizard said: USB doesn't work Expand On my Rock64, it is working fine ...
belfastraven Posted January 23, 2019 Posted January 23, 2019 As I noted earlier, I had problems with usb storage not being recognzed on a rock64 after update to the 4.20 kernel. In my case on a Rock64 v2.0 , I seemed to have fixed the problem by making the following changes which are reversions to the previous 4.19 dts values. vcc_host1_5v: vcc_otg_5v: vcc-host1-5v-regulator {############################# from 4.20, changed A2 back to D3 to make things work compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; usb2 { usb20_host_drv: usb20-host-drv { rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;################# from 4.20, changed A2 back to D3 to make things work My board is version 2.0 This problem did not affect other usb devices, btw, just storage... I tried to check the specs but didn't see find anything for vcc_host1_5v , vcc_otg_5v or usb20_host_drv. I did find usb_otg_drv at A2..... I noted the aobe in the pine64rock64 forum, but have had no response their yet. I am now back to booting off of a ssd on USB3 and having a usb stick and mouse/mouse keyboard on the usb2 ports-- once again, this is on a Rock64 v2.0 1
TonyMac32 Posted January 23, 2019 Posted January 23, 2019 Did we lose some patches? I haven't come around to Rockchip64.
sugatam Posted January 26, 2019 Posted January 26, 2019 I just got a rock64 v2.0 and can confirm that 4.20.0 does not recognize any usb storage device. Switching to 4.4.x works of course. I haven't had a chance to try the dts edit yet
