PlayingMuted Posted January 23, 2019 Posted January 23, 2019 Is the ESPRESSObin version 7 supported by Armbian?
Igor Posted January 23, 2019 Posted January 23, 2019 On 1/23/2019 at 6:04 AM, PlayingMuted said: Is the ESPRESSObin version 7 supported by Armbian? Expand Hard to say since there are so many different versions. I do have two (non v7) and both are the same ... Since we have most up2date firmware, I can speculate that yes.
ManoftheSea Posted January 23, 2019 Posted January 23, 2019 I have an EspressoBINv7, I'm running Armbian 5.72 (Stretch) with kernel 4.19. It appears to be supported. 2
Spemerchina Posted February 6, 2019 Posted February 6, 2019 On 1/23/2019 at 6:35 PM, ManoftheSea said: I have an EspressoBINv7, I'm running Armbian 5.72 (Stretch) with kernel 4.19. It appears to be supported. Expand On 1/23/2019 at 6:26 AM, Igor said: Hard to say since there are so many different versions. I do have two (non v7) and both are the same ... Since we have most up2date firmware, I can speculate that yes. Expand @Igor do you have a procedure for non-internal staff that would get v7 on the official support list? Maybe some of the guys could do the tests if what @ManoftheSea said is not enough. Thanks
Igor Posted February 6, 2019 Posted February 6, 2019 On 2/6/2019 at 8:37 AM, Spemerchina said: do you have a procedure for non-internal staff that would get v7 on the official support list? Expand There are no clear barriers between internal and external. If you or just somebody takes cover, than it will be supported. In any case it's hard to define "supported" for this board since nobody has all versions. 1
