No - you didnt missed anything ;)
Some images seem to need some "rework" - but mostly test/dev-images.
Did had the same on a image for a arm-TV-Box:
10 minutes ago, PlayingMuted said:
When I used the Debian image, it looks like the wireless-regdb's were not in the correct location.
Using this guide I was able to get CRDA to work.   wireless-regdb: Missing support for kernel direct loading
Did I miss something in the initial setup?
If you find a fix, here is our /lib/firmware https://github.com/armbian/firmware and here are general instructions: https://www.armbian.com/get-involved
@Igor
for me the fix was to put the files (attached as .zip)
regulatory.db
regulatory.db.p7s
out of  the tar-archive (or newer version)
http://ftp.be.debian.org/pub/software/network/wireless-regdb/wireless-regdb-2018.10.24.tar.xz
to /lib/firmware
and reboot
[    9.180263] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.187698] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Or did I missed something special? ;)
regulatory.zip
OK, now the question is whether we can just add this to the firmware package or not?
On 1/23/2019 at 10:34 PM, Igor said:
@Igor can we expand or replace this commit?
On a newer image I did get the dmesg-Message:
[    9.557455] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
I think because "we" have to replace 2 more files with the newer ones.
For the signature it is sforshee.key.pub.pem in /lib/crda/pubkeys/
and I did see additionally  regulatory.bin in /lib/crda
I dont know why they are "so old" in the packages
- crda - wireless Central Regulatory Domain Agent
- wireless-regdb - wireless regulatory database
actual mirror-archive of the original at http://ftp.be.debian.org/pub/software/network/wireless-regdb/wireless-regdb-2019.03.01.tar.gz
Original-files:
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/tree/
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/plain/regulatory.db
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/plain/regulatory.bin
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/plain/regulatory.db.p7s
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/plain/sforshee.key.pub.pem
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/plain/sforshee.x509.pem
I will attach a small archive with these four files here in the message.
see also:
wireless-regdb-2019.03.01.zip
I updated from the March 2019 to the June 2019 version :)
Extracted the files from
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/snapshot/wireless-regdb-master-2019-06-03.tar.gz
Just copy the 2 directorys (crda and firmware inside the lib-directory of the zipfile) to /lib/ and you will not get these errors in dmesg:
[    6.177259] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    6.177273] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
but
[    6.190055] cfg80211: Loading compiled-in X.509 certificates for regulatory database
@Igor in the past we did add these file with a commit, but the images I created yesterday for the BPI M2 Ultra/Berry didnt had it.
Is that because of csc-state of this board?
wireless-regdb_2019-06-03_lib.zip
We put those files out because they are already packed in iirc wireless-db package. You have to install that package as well.
Wrote on mobile
If I install the packages wireless-regdb
Spoiler
File list of package wireless-regdb in buster of architecture all
/lib/crda/regulatory.bin
/usr/share/doc/wireless-regdb/changelog.Debian.gz
/usr/share/doc/wireless-regdb/copyright
/usr/share/man/man5/regulatory.bin.5.gz
and crda
Spoiler
File list of package crda in buster of architecture armhf
/etc/default/crda /lib/crda/libreg.so
/lib/crda/pubkeys/benh@debian.org.key.pub.pem
/lib/crda/pubkeys/linville.key.pub.pem
/lib/crda/pubkeys/sforshee.key.pub.pem
/lib/crda/setregdomain
/lib/udev/rules.d/60-crda.rules
/lib/udev/rules.d/85-regulatory.rules
/sbin/crda
/sbin/regdbdump
/usr/include/reglib/nl80211.h
/usr/include/reglib/regdb.h
/usr/include/reglib/reglib.h
/usr/share/doc/crda/changelog.Debian.gz
/usr/share/doc/crda/copyright
/usr/share/lintian/overrides/crda
/usr/share/man/man8/crda.8.gz
/usr/share/man/man8/regdbdump.8.gz
then I will have the files
but do miss
/lib/crda/pubkeys/sforshee.x509.pem
/lib/firmware/regulatory.db
/lib/firmware/regulatory.db.p7s
and when loading the regulatory db my system is loading the x.509 certificate, which isnt in this 2 packages :(
