hi there,
Recently there was an update for all Olimex boards with A20. Now we have one image for all the boards and it includes mainline kernel which is cool. I checked here and took the image from here.
Now after a while I got strange error and wanted to check with you if you can share an opinion what this could be:
[32673.051479] Unable to handle kernel NULL pointer dereference at virtual address 0000
[32673.060027] pgd = 9d6652ac
[32673.062884] [00000000] *pgd=00000000
[32673.066666] Internal error: Oops: 5 [#1] SMP THUMB2
[32673.071795] Modules linked in: joydev input_leds ipt_MASQUERADE nf_conntrack_netlink iptable_nat nf_nat_ipv4 xt_addrtype iptable_filter xt_conntrack nf_nat nf_conntrack nf_netfilter bridge stp llc cifs ccm fscache overlay lz4hc lz4hc_compress zram rc_cec at2dec snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer sun4i_lradc_keys snd sun4i_ts sounm_hdmi sun4i_ss cec sun4i_drm sun8i_tcon_top sun4i_frontend sun4i_tcon uio_pdrv_genirq l libcomposite bonding ip_tables x_tables pwrseq_emmc
[32673.130283] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.19.10-sunxi #5.65
[32673.137406] Hardware name: Allwinner sun7i (A20) Family
[32673.142909] PC is at resched_curr+0x26/0x48
[32673.147313] LR is at check_preempt_curr+0x7f/0x84
[32673.152256] pc : [<c0139d12>]    lr : [<c013a7cf>]    psr: 000f01b3
[32673.158835] sp : c0d01d08  ip : ef6c87b0  fp : 2ea10000
[32673.164323] r10: ef6c8700  r9 : 00000000  r8 : ef6c8700
[32673.169813] r7 : c0d01d08  r6 : c0901ea0  r5 : c0d08a80  r4 : 00000000
[32673.176665] r3 : c0d00000  r2 : 00000000  r1 : c0d00000  r0 : 00000001
[32673.183519] Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[32673.191280] Control: 50c5387d  Table: 6c8ec06a  DAC: 00000051
[32673.197315] Process swapper/0 (pid: 0, stack limit = 0x385bb5af)
[32673.203623] Stack: (0xc0d01d08 to 0xc0d02000)
[32673.208212] 1d00:                   c0901f00 c0901f00 c0d01d18 c013a7cf ef6c8700 ea0
[32673.216802] 1d20: c0d01d74 c0d01d30 ea0d4bf8 c013a7ed ea0d4780 c012f663 80000000 ea0
[32673.225390] 1d40: c0d04f48 c0cb8700 c0d01d60 ea0d4bf8 00000000 ef6c8700 2ea10000 c01
[32673.233978] 1d60: c0901f00 b8023295 c0cb8700 600f0193 ea0d4800 ef6c8780 00000000 b80
[32673.242566] 1d80: ef6c8700 e5f55c10 00000000 00000000 c014fd75 ee7c5868 c0d01de8 000
[32673.251144] 1da0: 00000000 c014fd83 ee7c585c c014f7e7 00000004 00000001 2ea22000 ee7
[32673.259732] 1dc0: 00000001 00000003 00000000 c0d01de8 00000000 c0d04f48 600f0193 c01
[32673.268319] 1de0: 00000000 c0d01de8 00000000 00000000 00000000 c0d01df4 c0d01df4 b80
[32673.276907] 1e00: 00000400 ee7c5810 00000000 c0af4644 c0b1b080 0028f5be ee7c5870 600
[32673.285495] 1e20: ffffe000 c014f8ff 00000000 c073907f ee7c5810 c073909f 00000004 c01
[32673.294083] 1e40: ee01cfc0 ef100964 ef100900 00000000 00000035 ef03b800 c0d01ea0 c01
[32673.302671] 1e60: ef6c6450 c0623c2b 00001db7 c0d04f70 ef100900 c0de1ef8 00000000 c0d
[32673.311251] 1e80: ef100964 ef100900 00000000 00000001 ef03b800 c0cb7870 00000000 c01
[32673.319839] 1ea0: 00000000 b8023295 ef100900 ef100964 2ea10000 c015f495 ef100900 c0d
[32673.328427] 1ec0: 2ea10000 c0161cff c0cb8278 00000000 00000035 c015e8ed 0000008d c01
[32673.337015] 1ee0: c0d01f18 c0d05798 f080200c f0802000 c0d01f18 f0803000 c0d00000 c05
[32673.345603] 1f00: c0107a3c 400f0033 ffffffff c0d01f4c 00000000 c0101a65 00000000 0ea
[32673.354192] 1f20: ef6c3438 c0116721 ffffe000 c0d04f70 c0d04fb8 00000001 00000000 c0d
[32673.362772] 1f40: c0cb7870 00000000 ffffffff c0d01f68 c0107a3b c0107a3c 400f0033 fff
[32673.371360] 1f60: 00000051 00000000 00000000 c013ea9b c0de1893 ffffffff c013ed1d b80
[32673.410865] 1f80: 60000033 000000c5 00000001 ffffffff c0d04f48 c0d04f40 c0df8a00 ef6
[32673.450651] 1fa0: c0c5da34 c013ed1d 00000001 c0c00bbd ffffffff ffffffff 00000000 c0c
[32673.490033] 1fc0: 00000000 c0c5da34 b806219f 00000000 00000000 c0c00328 00000051 10c
[32673.529069] 1fe0: 100010bb 49a8f000 410fc074 50c5387d 00000000 00000000 00000000 000
[32673.567780] [<c0139d12>] (resched_curr) from [<c013a7cf>] (check_preempt_curr+0x7f/0
[32673.606194] [<c013a7cf>] (check_preempt_curr) from [<c013a7ed>] (ttwu_do_wakeup+0x19
[32673.644826] [<c013a7ed>] (ttwu_do_wakeup) from [<c013b2ff>] (try_to_wake_up+0x15b/0x
[32673.683009] [<c013b2ff>] (try_to_wake_up) from [<c014fd83>] (autoremove_wake_functio
[32673.721302] [<c014fd83>] (autoremove_wake_function) from [<c014f7e7>] (__wake_up_com
[32673.759336] [<c014f7e7>] (__wake_up_common) from [<c014f8c7>] (__wake_up_common_lock
[32673.796627] [<c014f8c7>] (__wake_up_common_lock) from [<c014f8ff>] (__wake_up+0x13/0
[32673.832721] [<c014f8ff>] (__wake_up) from [<c073909f>] (mv64xxx_i2c_intr+0x2b7/0x3ec
[32673.868190] [<c073909f>] (mv64xxx_i2c_intr) from [<c015f2d7>] (__handle_irq_event_pe
[32673.904795] [<c015f2d7>] (__handle_irq_event_percpu) from [<c015f42d>] (handle_irq_e
[32673.941488] [<c015f42d>] (handle_irq_event_percpu) from [<c015f495>] (handle_irq_eve
[32673.976927] [<c015f495>] (handle_irq_event) from [<c0161cff>] (handle_fasteoi_irq+0x
[32674.011371] [<c0161cff>] (handle_fasteoi_irq) from [<c015e8ed>] (generic_handle_irq+
[32674.045560] [<c015e8ed>] (generic_handle_irq) from [<c015ed8d>] (__handle_domain_irq
[32674.079597] [<c015ed8d>] (__handle_domain_irq) from [<c05cac95>] (gic_handle_irq+0x3
[32674.112894] [<c05cac95>] (gic_handle_irq) from [<c0101a65>] (__irq_svc+0x65/0x94)
[32674.145236] Exception stack(0xc0d01f18 to 0xc0d01f60)
[32674.175010] 1f00:                                                       00000000 0ea
[32674.207967] 1f20: ef6c3438 c0116721 ffffe000 c0d04f70 c0d04fb8 00000001 00000000 c0d
[32674.240863] 1f40: c0cb7870 00000000 ffffffff c0d01f68 c0107a3b c0107a3c 400f0033 fff
[32674.273876] [<c0101a65>] (__irq_svc) from [<c0107a3c>] (arch_cpu_idle+0x28/0x2c)
[32674.306067] [<c0107a3c>] (arch_cpu_idle) from [<c013ea9b>] (do_idle+0x14b/0x1d8)
[32674.338165] [<c013ea9b>] (do_idle) from [<c013ed1d>] (cpu_startup_entry+0x19/0x1c)
[32674.370035] [<c013ed1d>] (cpu_startup_entry) from [<c0c00bbd>] (start_kernel+0x3a7/0
[32674.402141] Code: 53ff 2001 f023 031f (691b) 42a3
[32674.430709] ---[ end trace 349b2715ffd50e9f ]---
[32674.458898] Kernel panic - not syncing: Fatal exception in interrupt
[32675.648500] SMP: failed to stop secondary CPUs
[32675.675135] Rebooting in 10 seconds..
[32686.861416] SMP: failed to stop secondary CPUs
thanks and regards,
Lazar
I’ve just tried to boot the theoretically universal Armbian_5.72.1_Olinuxino-a20_Debian_stretch_next_4.19.17 image (taken from ftp://staging.olimex.com/Allwinner_Images/A20-OLinuXino/1.latest_mainline_images/stretch/images/) on my A20-SOM device, but with no success.
The following output is displayed:
**File not found /boot/dtb/ **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via “fdt addr ” command.
Aborting!
** File not found /boot/dtb/overlay/sun7i-a20-fixup.scr **
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing…
Card did not respond to voltage select!
Device 0: unknown device
ethernet@01c50000 Waiting for PHY auto negotiation to complete…… TIMEOUT !
Could not initialize PHY ethernet@01c50000
I’d really appreciate any help with this, because I really need to make this work!!
Thanks in advance
